IP NHRP group (QoS)
rogerio.mota
I have a ip nhrp group configured with my DMVPN environment.  The policy is applied but don't have matches.
Interface Tunnel6000 <--> 10.12.14.8
  Service-policy output: 256k
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      5 minute offered rate 0000 bps, drop rate 0000 bps
      Match: any
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 0/0
      shape (average) cir 256000, bc 1024, be 1024
      target shape rate 256000
      Service-policy : QOSDMVPN
        queue stats for all priority classes:
          Queueing
          queue limit 512 packets
        Class-map: CL1 (match-any)
          0 packets, 0 bytes
          Match: ip dscp af11 (10)
          Queueing
          bandwidth 10% (25 kbps)
On the Spoke site everything is ok with a policy local. (Spoke to hub)
Tunnel6000
      3624884 packets, 508911052 bytes
      5 minute offered rate 6000 bps, drop rate 0 bps
      Match: any
      Queueing
      (queue depth/total drops/no-buffer drops) 0/279/0
      (pkts output/bytes output) 3537676/567364511
          Queueing
          (pkts output/bytes output) 604725/57168595
          778093 packets, 153844401 bytes
          5 minute offered rate 0 bps, drop rate 0 bps
            5 minute rate 0 bps
          Queueing
          (pkts output/bytes output) 778092/167156279
On the hub this is the policy configuration and nhrp command.
Policy Map 256k
    Class class-default
      Average Rate Traffic Shaping
      cir 256000 (bps)
      service-policy QOSDMVPN
ip nhrp map group g256 service-policy output 256k
It's running on a ASR1002
Thanks.
0 Replies 0
