ip pgm router
Mjoyce0011
Visitor
Forgive me if this is already asked.  I am installing a new switch and need to deploy Pragmatic General Multicasting.  I have configured my layer 3 interface but the command (ip pgm router) is unavailable/deprecated.  I can't seem to find any documentation as to what the new command would be for IOS XE 16.9.2 (Fuji).  If anyone has any helpful info, it would be greatly appreciated.
Notes:
Cisco 9407 (IOS XE 16.9.2)
Interface - TenGig SFP (currently shutdown)
  • Layer 3 enabled
  • ip pim dense-mode
  • OSPF
  • QoS
  • Service Policy applied
Commands entered:
(config)#ip routing
(config)#ip multicast-routing
(config)#int te2/0/1
(config-if)#ip ? (Not available - %Unrecognized command)
luis_cordova
Hi @Mjoyce0011 ,
Apparently, this command is not supported by that version:
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/software/release/16-9/release_notes/ol-16-9-3850.html
Unsupported Features
  • 802.1x Configurable username and password for MAC Authentication Bypass (MAB)
  • Cisco Group Management Protocol (CGMP)
  • Cisco Plug-In for OpenFlow (OpenFlow 1.0 and 1.3) is available in Cisco IOS XE Release 3.7.3E, but is not supported in Cisco IOS XE Fuji 16.8.x.
  • Cisco TrustSec 802.1x
  • Cisco TrustSec critical authentication
  • Cisco Networking Services (CNS) configuration agent
  • Converged Access (CA) is not supported beyond Cisco IOS XE Denali 16.3.x.
    On the Cisco Catalyst 3850 Series Switches, CA is supported in the Cisco IOS XE Denali 16.3.x software release, which has extended support for 40 months.
  • Command Switch Redundancy
  • Device classifier for Auto Smartports (ASP)
  • Dynamic Host Configuration Protocol (DHCP) snooping ASCII circuit ID
  • DHCP version 6 (DHCPv6) relay source configuration
  • Distance Vector Multicast Routing Protocol (DVMRP) tunneling
  • Dynamic access ports
  • Fallback bridging for non-IP traffic
  • IEEE 802.1X-2010 with 802.1AE support
  • Improvements in QoS policing rates
  • Ingress Strict Priority Queuing (Expedite)
  • IP-in-IP (IPIP) Tunneling
  • IP SLA Media Operation
  • IPv6 support for Internet Key Exchange (IKE) versoin 2 / IP Security (IPSec) version 3
  • IPv6 ready logo phase II - host
  • IPv6 static route support on LAN Base images
  • IPv6 strict host mode
  • Layer 2 tunneling protocol enhancements
  • Link-state tracking
  • Mesh, FlexConnect, and OfficeExtend access point deployment
  • Medianet
  • MSE 8.x is not supported with Cisco IOS XE Denali 16.x.x.
  • Passive monitoring
  • Per VLAN policer
  • Performance Monitor (Phase 1)
  • Port security on EtherChannels
  • Pragmatic General Multicast (PGM)
  • RFC 4292 IP-FORWARD-MIB (IPv6 only)
  • RFC 4293 IP-MIB (IPv6 only)
  • RFC4292/RFC4293 MIBs (IPv6 only)
  • RFC5460 DHCPv6 Bulk leasequery
  • Stack ports buffer is not shared as part of the shared pool. The dedicated buffer for stack ports can only be used by stack ports.
  • Trust boundary configuration
  • UniDirectional Link Routing (UDLR)
  • VLAN access control lists (VACL) logging of access denied
  • Virtual Routing and Forwarding (VRF)-Aware web authentication
  • Web-Based Authentication without SVI
  • Weighted Random Early Detection (WRED)
Hi Luis,
    Thank you for your reply.  I see the command was deprecated in this version of IOS, but what I am looking for is what to use instead of PGM.  I have an application that relies on it(PGM) but the vendor doesn't have documentation for newer version of IOS that don't support PGM.  Is it as simple as enabling ip multicast-routing and expect it to work?
