ip pim hello-interval vs ip pim query-interval command
Charlie Grey
what is the different between these 2 commands? Confused.
Giuseppe Larosa
Hello @Charlie Grey ,
ip pim hello-iinterval specifies when PIM hellos are sent to keep up a PIM adjacency. Default value should be 30 seconds.
I have found the following good explanation, they are actually the same but query refers to PIM version 1.
>> Use this command to configure the frequency of PIM neighbor discovery messages. By default these messages are sent once every 30 seconds. In PIM Version 1 (PIMv1), these messages are referred to as PIM query messages; in PIM Version 2 (PIMv2), these messages are referred to as PIM hello messages. By default, routers run PIMv2 and send PIM hello messages. A router will change (auto-fallback) to PIMv1 and will send PIM query messages if it detects a neighboring router that only supports PIMv1. As soon as that neighboring PIMv1 router is removed from the network, the router will revert to PIMv2.
Hope to help
Giuseppe
Giuseppe Larosa
Hope to help
Giuseppe
