IP Policy ignored
Frank Sinatra
I have a router with a default route set to the first WAN. I want to set up a second WAN but can't remove the default route because the router is live. I have added an ip policy to the second WAN interface but it is being ignore and it uses the default route of the first WAN instead (I have confirmed using trace). Here's my config:
aaa new-model
aaa authentication login default local
ip dhcp excluded-address 10.10.10.1 10.10.10.10
ip dhcp excluded-address 10.10.20.1 10.10.20.10
ip dhcp pool Vlan10
 network 10.10.10.0 255.255.255.0
 default-router 10.10.10.1
 dns-server 8.8.8.8 8.8.4.4
ip dhcp pool Vlan20
 network 10.10.20.0 255.255.255.0
 default-router 10.10.20.1
ip domain name test.com
ip name-server 8.8.8.8
ip name-server 8.8.4.4
interface FastEthernet0
 switchport access vlan 2
interface FastEthernet1
 switchport access vlan 3
interface Vlan1
 shutdown
interface Vlan2
 description WAN-1
 ip address 1.1.1.2 255.255.255.252
 ip nat outside
 ip virtual-reassembly in
interface Vlan3
 description WAN-2
 ip address 2.2.2.2 255.255.255.252
ip nat outside ip virtual-reassembly in ! interface Vlan10 description LAN-1 ip address 10.10.10.1 255.255.255.0 ip nat inside ip virtual-reassembly in ! interface Vlan20 description LAN-2 ip address 10.10.20.1 255.255.255.0 ip nat inside ip virtual-reassembly in ip policy route-map PBR ! ip nat inside source list Vlan10 interface Vlan2 overload ip nat inside source list Vlan20 interface Vlan3 overload ip route 0.0.0.0 0.0.0.0 1.1.1.1 ! ip access-list extended Vlan10 permit ip 10.10.10.0 0.0.0.255 any ip access-list extended Vlan20 permit ip 10.10.20.0 0.0.0.255 any route-map PBR permit 10 match ip address Vlan20 set ip next-hop 2.2.2.1
This is a follow-up to this discussion:
https://community.cisco.com/t5/routing/two-active-wan-connections/m-p/3815883#M311082
15 Replies 15
Glad to get the update that it is working. Your issue is actually the expected behavior. When you configure PBR with a route map on the interface it operates on traffic received on that interface and not on traffic generated by the router itself. If you want PBR to work on traffic generated by the router then you need to configure ip local policy.
Rick
Rick
