IP prefix-list for /32 subnet (remote VPN usr)
Kyujin Choi
 Hi there. I would like to get expertise about
IP prefix-list
to define remote VPN users.
 Currently, 10.1.2.0/24 is for remote VPN subnet.
 OSPF route table has 10.1.2.x/32. Belows are examples for remote VPN routes (/32)
 10.1.2.91/32, 10.1.2.103/32, 10.1.2 11/32 etc (Basically, I need to define every /32 route of 10.1.2.x/32 by using
IP prefix-list
  How do I define each user's subnet 10.1.2.x/32 with
IP prefix-list?
Eventually I will redistribute OSPF route to BGP along with
 IP prefix-list
Thanks!
 IP prefix-list remote-vpn seq 10 permit 10.1.2.0/32
(Is this right?)
Hi @Kyujin Choi ,
If you only want to allow all the /32 prefixes belonging to 10.1.2.0/24, you need the following
prefix-list:
IP prefix-list remote-vpn seq 10 permit 10.1.2.0/24 ge 32
5 Replies 5
can you more elaborate?
Above IP prefix contains all 10.1.2.x/32 subnet?
try this
ip prefix-list NAME permit 10.1.2.x/24 le 32
@Harold Ritter
his suggestion is better than Me,
I use Le or equal 32 <<- this meaning any prefix that bit 24 must match the prefix and have mask less than or equal 32 (if some how you have 30, not in this VPN router but in other router that make conflict)
he use ge or equal 32  <<- this meaning any prefix that bit 24 must match the prefix and have mask grater than or equal 32, BUT the 32 is greatest number so this will match only 32, and you will not face any issue in OSPF network.
Hi @Kyujin Choi ,
prefix-list:
