Ip prefix-list
kumarpmt83
i have cisco 2800 router with the following config:
we have two service provider.
Lan IP : 10.10.70.0/23
Bsnl wan : 192.168.24.56/30
Tata wan : 10.70.56.36/30
router bgp 95001
no synchronization
bgp log-neighbor-changes
network 10.10.70.0 mask 255.255.254.0
network 10.10.70.0 mask 255.255.255.0
network 172.16.0.3 mask 255.255.255.255
neighbor 10.70.56.35 remote-as 6855
neighbor 10.70.56.35 route-map EBGP-TATAWAN out
neighbor 192.168.24.57 remote-as 7839
neighbor 192.168.24.57 description ***EBGP Peer to BSNL***
neighbor 192.168.24.57 soft-reconfiguration inbound
neighbor 192.168.24.57 weight 100
neighbor 192.168.24.57 route-map EBGP-BSNLWAN out
ip prefix-list BSNL-LANROUTES seq 10 permit 10.10.70.0/24
ip prefix-list BSNL-LANROUTES seq 20 permit 10.10.70.0/23
ip prefix-list TATA-LANROUTES seq 10 permit 10.10.71.0/24
ip prefix-list TATA-LANROUTES seq 20 permit 10.10.70.0/23
route-map EBGP-TATAWAN permit 10
match ip address prefix-list TATA-LANROUTES
route-map EBGP-BSNLWAN permit 10
match ip address prefix-list BSNL-LANROUTES
what does mean the above configuration.
what is prefix-list??what is the purpose we use it??
i have confused with the configuration.
Can anyone tell me...
20 Replies 20
are you still advertising  10.10.71.0/24 to Tata only from the client site?
Remeber the "longest match wins!" routing rule.
So the  BSNL router in your HQ might be receiving the 10.10.71.0/24 route via Tata somehow.
Are you abel to check?
sh ip bgp 10.10.70.0/23 longer
issued on the BSNL router should show you all prefixes necessary if received via BGP.
sh ip route static | in  10.10.71.
sh ip route static | in  10.10.70.
issued for sure should show any possible static configured for the client site.
HTH,
Milan
Now i removed 10.10.71.0/24 prefix to Tata in client side and it is working.
But in the Bsnl prefix 10.10.70.0/24 & 10.10.70.0/23 not removed in the client side.
It is ok or not.
Thank u very much guys for all the valuable post.
it is very helpful for me.
as we discussed with Kishore here, there are different possibilities how to make one provider connection preferred for incoming traffic.
You can advertise  10.10.70.0/24 and 10.10.71.0/24 to BSNL and  (only) 10.10.70.0/23  to Tata in your case, e.g.
Or you can  advertise 10.10.70.0/23 (only) to both providers and prepend the client site AS number several times when advertising to Tata.
Or you can use communities agreed with your providers.
But it's your decision based on the detailed knowledge of your network, we can give you just general recommendations here.
BR,
Milan
Dinesh,
you need to use local-pref on your primary link and AS-PATH prepend on your backup link if you are going to advertise 10.10.70.0/23 on both links. . This will ensure that the routing is optimal and not asymetrical.
Please free to ask further
Kishore
local-pref has no sense if weight is set alreday and only a single CE router is on the site.
AS-PATH prepend on the backup link might not be enough if each line is provided by a different provider.
BR,
Milan
Hi Milan,
Didn't notice he was talking about one CE.
I just read his last post and thought it was dual routers multihomed
Cheers, Kishore
