ip route and traceroute
lmanavalan
i executed "traceroute 10.71.252.18" and the result is
internalrouter#traceroute 10.71.252.18
Tracing the route to 10.71.252.18
  1 10.71.0.34 132 msec
    10.71.0.30 136 msec
    10.71.0.34 132 msec
  2 10.64.128.42 136 msec
    10.64.144.42 132 msec
    10.64.128.42 140 msec
Does this means that it has 2 routes to the destination
And also i executed "sh ip route 10.71.252.18" the result is
internalrouter#sh ip route 10.71.252.18
Routing entry for 10.71.252.16/30
  Known via "ospf 1", distance 110, metric 30, type intra area
  Last update from 10.71.0.34 on Tunnel10, 00:19:06 ago
  Routing Descriptor Blocks:
  * 10.71.0.34, from 10.64.147.1, 00:19:06 ago, via Tunnel10
      Route metric is 30, traffic share count is 1
    10.71.0.30, from 10.64.147.1, 00:19:06 ago, via Tunnel9
what is the symbol * represents. Does it means there are two routes available and the route with the * is the prefered one
Logesh
5 Replies 5
Reza Sharifi
Hi Logesh,
No, 1,2 in the trace route are sequence numbers.  Check your tunnel config as it looks like you have a loop in your network, because 10.71.0.34 132 and 10.64.128.42 appear twice in your trace route.
Yes, * means that is the active route
Reza
i believe thats not the Loop in the Network thats the Redundant Path to the destination
Logesh
Logesh:
Youre right, there is no loop.
Victor
Tharak Abraham
Level 3
Level 3
Redundant paths !
Could you please post a "sh ip route" of the routing table too ?
please try with a traceroute xxxx source yyyy and see if there is any change in the observation !
(yyyy being the interface where you intend to source the udp probes)
mlund
Level 7
Level 7
Hi Logesh
The result clearly indicate that there is two paths to the destination.
Traceroute toggles each probe between the different equal cost paths that is avalable.
*—Indicates the last path used when a packet was forwarded. It pertains only to the nonfast-switched packets. However, it does not indicate which path will be used next when forwarding a nonfast-switched packet, except when the paths are equal cost.
/Mikael
