IP Route entry not showing up in routing table for VPN routing
slee
I created a VPN tunnel between our router (2800) and the Amazon Cloud.  The tunnel is fine, but when I try to enter the routing for the network in the cloud, the entry does not show up in the routing table although it shows up when I run sh run | i ip route.  I heard this could happen when there is a directly connected route that overlaps the route being added, but I don't believe that is the case here.  Here is the routing table:
Gateway of last resort is 108.48.76.1 to network 0.0.0.0
     50.0.0.0/28 is subnetted, 1 subnets
C       50.76.16.192 is directly connected, GigabitEthernet0/0.100
     169.254.0.0/30 is subnetted, 2 subnets
C       169.254.255.0 is directly connected, Tunnel1
C       169.254.255.4 is directly connected, Tunnel2
     157.130.0.0/30 is subnetted, 1 subnets
C       157.130.45.232 is directly connected, MFR0.500
     65.0.0.0/24 is subnetted, 1 subnets
C       65.196.96.0 is directly connected, GigabitEthernet0/0.10
     10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
C       10.10.2.0/24 is directly connected, GigabitEthernet0/1
S       10.10.5.0/24 [1/0] via 10.10.2.2
C       10.0.0.0/24 is directly connected, Loopback0
S       10.200.0.0/14 [1/0] via 10.10.2.2
     108.0.0.0/24 is subnetted, 1 subnets
C       108.48.76.0 is directly connected, GigabitEthernet0/0.1000
S*   0.0.0.0/0 [1/0] via 108.48.76.1
The network I am trying to add is 10.208.0.0/16 on interface Tunnel1
5 Replies 5
Mitchell Dyer
Is the tunnel up/up?
The tunnel interface (and associated routes) will act just like any other, if the interface is down then the route will not appear in the routing table.
-Mitch
Yes, the tunnel is up/up, sh cry isa sa shows state QM_IDLE and status active.  There have been no packets in or out.
Would you mind posting the rest of your config? If not all, I'd like to see the crypto map/VTI and all associated ACLs, NAT statements and IKE/IPSec info.
here is the crypto map:
Crypto Map "Tunnel1-head-0" 65536 ipsec-isakmp
        Profile name: ipsec-vpn-b5b756dc-0
        Security association lifetime: 4608000 kilobytes/3600 seconds
        PFS (Y/N): Y
        DH group:  group2
        Transform sets={
                ipsec-prop-vpn-b5b756dc-0,
Crypto Map "Tunnel1-head-0" 65537 ipsec-isakmp
        Map is a PROFILE INSTANCE.
        Peer = 72.21.209.224
        Extended IP access list
            access-list  permit ip any any
        Current peer: 72.21.209.224
        PFS (Y/N): Y
        DH group:  group2
        Transform sets={
        Always create SAs
        Interfaces using crypto map Tunnel1-head-0:
                Tunnel1
Crypto Map "Tunnel2-head-0" 65536 ipsec-isakmp
        Profile name: ipsec-vpn-b5b756dc-1
        PFS (Y/N): Y
        DH group:  group2
        Transform sets={
                ipsec-prop-vpn-b5b756dc-1,
Crypto Map "Tunnel2-head-0" 65537 ipsec-isakmp
        Peer = 72.21.209.192
        Current peer: 72.21.209.192
        PFS (Y/N): Y
        DH group:  group2
        Transform sets={
        Always create SAs
        Interfaces using crypto map Tunnel2-head-0:
                Tunnel2
No ACLs or NAT statements associated with this.  What IKE/IPSec info?
Nevermind, it was the track that was screwing things up
