ip routing command doesn't work on cisco 9000v
nsom
Hi I am trying to enable routing on cisco 9000v for intervlan routing betwen two vlans.
I am trying to enable routing as explained in different articles using ip routing command however this command doesn't work as there are other options that need to be executed post this command and I ma not sure what to use. Please suggest
switch(config)# ip routing
event-history   internal        multicast
% Incomplete command at '^' marker.
44 Replies 44
 Nexus you be the command
conf t
feature interface-vlan
Hi Flavio,
I am not sure I quite followed what you said
If you are talking about interface-vlan feature that's already enabled.
switch(config)# feature interface-vlan
switch(config)#
switch(config)#
I believe the routing will work after that.  Did you try to setup ip address on two interfaces vlan and they did not ping each other?
nsom
That's right
Eth1/1          2003    eth  access up      none                     1000(D)
Eth1/2          2003    eth  access up      none                     1000(D)
Eth1/3          2004    eth  access up      none                     1000(D)
I have assigned 2003 an ip of 192.168.15.1 and 2004 as 192.168.20.1, the hosts ips are 192.168.15.2(host1) and 192.168.20.2(host2)
I have set the gateway of the host1 as 192.168.15.1 which is the gateway of the vlan2003.
I am able to ping 192.168.15.1 from host1, however ping doesn't go through when I try to it from host1 to gateway2 i.e 192.168.20.1(vlan2004)
Which licensing do you have on this device?
the NSK dont add VLAN automatic when you config switchport with access vlan
you need to add vlan to DB by
VLAN2003
VLAN2004
switch(config)# show vlan
VLAN Name                             Status    Ports
1    default                          active    Eth1/4, Eth1/5, Eth1/6, Eth1/7
                                                Eth1/8, Eth1/9, Eth1/10, Eth1/11
                                                Eth1/12, Eth1/13, Eth1/14
                                                Eth1/15, Eth1/16, Eth1/17
                                                Eth1/18, Eth1/19, Eth1/20
                                                Eth1/21, Eth1/22, Eth1/23
                                                Eth1/24, Eth1/25, Eth1/26
                                                Eth1/27, Eth1/28, Eth1/29
                                                Eth1/30, Eth1/31, Eth1/32
                                                Eth1/33, Eth1/34, Eth1/35
                                                Eth1/36, Eth1/37, Eth1/38
                                                Eth1/39, Eth1/40, Eth1/41
                                                Eth1/42, Eth1/43, Eth1/44
                                                Eth1/45, Eth1/46, Eth1/47
                                                Eth1/48, Eth1/49, Eth1/50
                                                Eth1/51, Eth1/52, Eth1/53
                                                Eth1/54, Eth1/55, Eth1/56
                                                Eth1/57, Eth1/58, Eth1/59
                                                Eth1/60, Eth1/61, Eth1/62
                                                Eth1/63, Eth1/64
2003 VLAN2003                         active    Eth1/1, Eth1/2
2004 VLAN2004                         active    Eth1/3
2005 VLAN2005                         active
VLAN Type         Vlan-mode
1    enet         CE
2003 enet         CE
2004 enet         CE
2005 enet         CE
Remote SPAN VLANs
Primary  Secondary  Type             Ports
I believe vlan is already added to db
show interface ip brief
switch(config)# show ip interface brief
IP Interface Status for VRF "default"(1)
Interface            IP Address      Interface Status
Vlan2003             192.168.15.1    protocol-up/link-up/admin-up
Vlan2004             192.168.20.1    protocol-up/link-up/admin-up
Vlan2005             192.168.12.1    protocol-down/link-down/admin-up
nsom
show version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_series_home.html
Copyright (c) 2002-2021, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Nexus 9000v is a demo version of the Nexus Operating System
Software
  BIOS: version
NXOS: version 9.3(7a)
  BIOS compile time:
  NXOS image file is: bootflash:///nxos.9.3.7a.bin
  NXOS compile time:  6/18/2021 0:00:00 [06/18/2021 01:31:45]
Hardware
  cisco Nexus9000 C9300v Chassis
  Intel(R) Xeon(R) Gold 6240 CPU @ 2.60GHz with 8163732 kB of memory.
  Processor Board ID 94OMPAIMD33
  Device name: switch
  bootflash:    4287040 kB
Kernel uptime is 3 day(s), 3 hour(s), 46 minute(s), 17 second(s)
Last reset
  Reason: Unknown
  System version:
  Service:
plugin
  Core Plugin, Ethernet Plugin
Active Package(s):
It's cisco 9000v, created this vm using the ova of cisco 9300 virtual switch from the cisco website
show license usage
show run int Eth1/1
show run int Eth1/3
please
You are going to need to create VRF first.
Take a look on this video
https://www.youtube.com/watch?v=GWTLCCuhz6I
I am trying to setup a simple routing between two hosts (residing in different vlans)using the switch as a layer 3.
Do I need to setup the VRF for this simple communication?
I basically want to setup multi layer switch vlan routing using a single switch
This video talks about it
https://www.youtube.com/watch?v=NmkFzDrZsXM
