IP Scheme Design
chenamys
Community Member
IP Scheme should be simple and summarizeable
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
The original purpose of IP addresses is to provide a physical unique identification for delivery of packets.  To allow scalability, the IP address is split into a network number and a host number.  To allow even larger scalability, network numbers are aggregated, sharing the same binary prefix, to reduce routing table sizes.  Both networks and aggregated networks are generally tied to the physical topology.
In addition to using IP addressing to deliver packets on networks, network numbers have often been used for some type of access control.  The latter is what causes problems when an IP address that's more or less required to represent some location in the physical topology is also used for some kind of role control.  E.g. network 5 contains our servers, network 6 contains sales agents, or network 50 for data and network 51 for VoIP.
With laptops, user roles can't as easily be tied to a network number, and likewise, be used for something like a software based VoIP phone on a PC.
Consider using IP addressing just for L3 topology purposes, and some other method for role/use identification.  I would suggest you discard your 3 options and think "outside the box".  How might you "identify" data, VoIP and/or video without using IP addressing?
Jeff Van Houten
Level 11
Level 11
From a security perspective Cisco would recommend something closer to #1 so you can acl the voice (and video??) separately from the data.
