IP SLA and Tracking for alerting
Patrick McHenry
Level 4
Level 4
I configured IP SLAs for sites that connect to the Internet via a 2911 router
Config:
ip sla 199
 icmp-echo 4.2.2.2 source-interface GigabitEthernet0/2
ip sla schedule 199 life forever start-time now
ip sla logging traps
track 199 ip sla 199
 delay down 120 up 120
Works great - sends a syslog message to the Solarwinds box and message sets off an email alert.
We have a couple of smaller sites that connect to the Internet via a 5510. I'm trying to accomplish the same thing but, it doesn't seem to have the options to set a "delay down and delay up"
Below seems to be my only option:
"track 199 rtr 199 reachability"
Will this tracking-config log the ping fail and if so, is there a way to delay the logging for 120 secs - for Up and Down events?
Thanks, Pat
Bilal Nawaz
Hello Pat,
Have you tried entering the command "track 199 rtr 199 reachability"
The prompt should look like this after:
Router(config-track)#
Here you should be able to enter the command "delay down 120 up 120" to my recollection.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
I don't think so - I believe I stayed in config mode after track 199 rtr 199 reachabilty. I'll try again later though.
