IP SLA failover on dual dhcp WAN links
pkaretnikov
outside
A    B
  R
inside
R=2801 Router, A and B are the WAN links.
While having a dual WAN interface is normally not an issue, both of the links use DHCP, so when you attempt to place a track stament on the route, it's not an option if you include gaining the route via DHCP.
Router(config)#no ip route 0.0.0.0 0.0.0.0 fastEthernet 0/0.2 dhcp ?
  <1-255>  Distance metric for this route
  <cr>
Router(config)#no ip route 0.0.0.0 0.0.0.0 fastEthernet 0/0.2 track 1 ?
  name     Specify name of the next hop
  tag      Set tag for this route
  <cr>
The DHCP statement is definately required yet I can't have tracking and a dhcp based default route. Technically I could create a couple VRFs and have them act as an outside routers and my inside router would not have to get anything from DHCP but that seems a bit convoluted. Has anyone else ran into this and have any idea of a workaround or if there is a fix in a later IOS(currently running 12.4(24)T4).
Lei Tian
Use "ip dhcp client route track" under the interface.
http://www.cisco.com/en/US/docs/ios/ipaddr/command/reference/iad_dhc1.html#wp1041855
HTH,
Lei Tian
