IP SLA Failover
justinoleary911
someone please help
the track goes on the primary route:
ip route 0.0.0.0 0.0.0.0 50.225.187.209 track 1 <-- primary route
ip route 0.0.0.0 0.0.0.0 70.89.25.230 10 <-- secondary route with higher AD
28 Replies 28
do you want the spoke to access the Internet directly from the spoke (and not through the hub) ?
someone please help
first of all, there seems to be a simple typo in your hub configuration, try and change that and see what happens; Fiber and fiber do not match, so it has to be either Fiber/Fiber or fiber/fiber (capitalized or non-capitalized):
ip nat inside source route-map Fiber interface GigabitEthernet0/0/0 overload
route-map fiber permit 10
match ip address 103
match interface GigabitEthernet0/0/0
Hello
Just to add also try...
no access-list 103
ip access-list 103 permit ip 192.168.110.0 0.0.0.255 any
res
Paul
Kind Regards
Paul
hi paul,
are you saying to add this into the hub, and it should fix the issue?
Hello
If applicable test it and see if it makes the difference,  In the current acl you have a lot going on and basically all what you want to do is specify the subnets required for translation.
res
Paul
Kind Regards
Paul
I don't wan to be annoying, but your NAT statement refers to a non-existing route map, so nothing will work until you change that...
should be
ip nat inside source route-map fiber interface GigabitEthernet0/0/0 overload
your not being annoying,  thank you for your help ,  ill post again after these changes are made.  thanks again
Well that worked for the NAT issue and I am able to get to the internet at my hub site, However I am running into another problem with the tunnels coming up. and connecting to the spokes.
I have no Tunnel communication but they all say UP on both sides. This is for my Tunnel 1 config. Tunnel 0 is working when the line is live.
Thanks again for your help.
I noticed a slight difference in your crypto configurations. Make sure they are exactly the same on both sides (for the sake of clarity, I have also changed the policy number). Since you are using the same profile for different tunnels, add the 'shared' keyword.
Here are the revised configs (changes in bold):
HUB
crypto isakmp policy 30
encr 3des
hash md5
authentication pre-share
group 2
lifetime 28800
crypto isakmp keepalive 30
crypto ipsec profile PremierIpsec
set security-association lifetime seconds 900
set transform-set strong
interface Tunnel0
ip address 10.0.0.1 255.255.255.0
no ip redirects
ip mtu 1428
ip nhrp map multicast dynamic
ip nhrp network-id 1
ip nhrp holdtime 1200
ip ospf network broadcast
ip ospf priority 2
tunnel source GigabitEthernet0/1
tunnel mode gre multipoint
tunnel key 0
tunnel protection ipsec profile PremierIpsec shared
interface Tunnel1
ip address 10.0.1.1 255.255.255.0
no ip redirects
ip mtu 1428
ip ospf priority 2
ip ospf 1 area 0
ip ospf cost 5000
keepalive 10 3
tunnel source GigabitEthernet0/0/0
tunnel key 2
SPOKE
encr 3des
hash md5
group 2
lifetime 28800
crypto ipsec profile VanoreIpsec
interface Tunnel0
ip address 10.0.0.10 255.255.255.0
no ip redirects
ip mtu 1428
ip nhrp map multicast 70.89.25.225
ip nhrp map 10.0.0.1 70.89.25.225
ip nhrp holdtime 300
ip nhrp nhs 10.0.0.1
ip ospf priority 0
tunnel key 0
tunnel protection ipsec profile VanoreIpsec shared
interface Tunnel1
ip address 10.0.1.10 255.255.255.0
no ip redirects
ip mtu 1428
ip nhrp map multicast 50.225.187.210
ip nhrp map 10.0.1.1 50.225.187.210
ip nhrp nhs 10.0.1.1
ip ospf cost 5000
ip ospf priority 0
ip ospf 1 area 0
tunnel key 2
someone please help
someone please help
my bad, I overlooked that your tunnels on the hub have different sources. What happens  if you just configure 'shared' on the spoke ?
someone please help
