IP SLA for DNS trigger problem
Majed Saeed
Hi Folks
I'm facing an issue while configuring IP SLA for DNS trigger between two routers connected to each other like R1 <<>> R2 .
R1 - IP 10.1.2.1
R2 - IP 10.1.2.2
Please find below helpful logs .. Looking for your thankful assistance
R1 Config.
ip sla 1
 dns 10.1.2.2 name-server 10.1.2.2 source-port 53
 timeout 100
 threshold 500
 frequency 9
ip sla schedule 1 life forever start-time now
R1 show ip sla statistics
R1#sh ip sla statistics
Round Trip Time (RTT) for       Index 1
        Latest RTT: NoConnection/Busy/Timeout
Latest operation start time: *00:13:56.363 UTC Fri Mar 1 2002
Latest operation return code: Timeout
Number of successes: 0
Number of failures: 36
Operation time to live: Forever
 R1 debug ip sla err
*Mar  1 00:11:59.371: IP SLAs(1) dns operation: Error code=4
*Mar  1 00:11:59.371: IP SLAs(1) Scheduler: Updating result
*Mar  1 00:11:59.375: IP SLAs(1) Scheduler: start wakeup timer, delay = 8988
R1#
*Mar  1 00:12:08.363: IP SLAs(1) Scheduler: saaSchedulerEventWakeup
*Mar  1 00:12:08.363: IP SLAs(1) Scheduler: Starting an operation
*Mar  1 00:12:08.367: IP SLAs(1) dns operation: Starting dns operation
*Mar  1 00:12:08.367: IP SLAs(1) dns operation: Query addr - 10.1.2.2
*Mar  1 00:12:08.367: IP SLAs(1) dns operation: actual target queried = 2.2.1.10.in-addr.arpa
R1#
*Mar  1 00:12:17.371: IP SLAs(1) dns operation: Error code=4
*Mar  1 00:12:17.371: IP SLAs(1) Scheduler: Updating result
*Mar  1 00:12:17.375: IP SLAs(1) Scheduler: start wakeup timer, delay = 8988
5 Replies 5
Terence Payet
You have to configure the other router as a dns server.
But i dont think it will work. Unless you were querying a working dns server.
But based on the debug output the ip sla source is trying to query the dns server as per the output below:
Please rate helpful post.
Steve
Hi Steve
It is already R2 as DNS server
Why are you trying to resolve the "10.1.2.2" string in DNS? This would actually mean that you want a reverse lookup from an IP address back to a fully qualified domain name, that is, a PTR record. You would need to create a PTR record on the DNS for this purpose. Usually, you should be looking for a normal lookup from a domain name to an IP address, such as "www.google.com" or "www.yourdomain.com".
Best regards,
Peter
Hi Peter
I just thought that since 10.1.2.2 is R2 interface IP and as long as configured the same as DNS server through CLI . That might make R2 as server for lookup . Could you please elaborate me more how can make this works .
Hi Majed,
The SLA probe should be configured similarly to this:
ip sla 1
 dns www.google.com name-server 10.1.2.2 source-port 53
 timeout 100
 threshold 500
 frequency 9
Best regards,
Peter
