IP SLA or some other configuration
TRACY HARTMANN
I have a layer 3 switch that has two circuits 1 Gig and 1 10 Gig to the same location.  I want to use them as Primary and backup.  We have tried to do this with just a EIGRP routing option but doesn't seem to be taking over correctly.   Could I possible do something with ip SLA which says
Interface G01
ip address 10.20.0.1
interface Tg01
ip address 10.20.0.5
then do a track of 10.20.0.6 the other side of the Ten gig, if it goes away it woud route to the 10.20.0.1
I could do a route-map with a next-hop but what would be the best solution?
an IP SLA is definitely an option.
track 1 ip sla 1 reachability
ip sla 1
icmp-echo 10.0.0.6 source-ip 10.0.0.5
frequency 5
ip sla schedule 1 start-time now life forever
ip route 0.0.0.0 0.0.0.0 10.0.0.6 track 1
ip route 0.0.0.0 0.0.0.0 10.0.0.2 200
I am assuming I need to put this on both routers on either side...
does the other side consist of one or two routers ? If it is one router, you can indeed mirror the suggested config.
Giuseppe Larosa
Hello TRACY,
to make it work with EIGRP it is just enough to increase delay on the giga interface. Because EIGRP metric is cumulative on delay.
interface giga01
delay 10000
doing it on both sides should make the tengiga link preferred.
Hope to help
Giuseppe
