IP SLA 'path-jitter'
johnlloyd_13
Level 9
Level 9
hi,
i'm trying to monitor an IPSec VPN tunnel for latency, jitter and packet loss.
udp-jitter using g729a codec doesn't seem to work and i don't see the option for 'icmp-jitter' in an ASR1K. is this the same as 'path-jitter' option?
also what's the difference between a positive and negative jitter? what field or value should i refer to when monitoring jitter in IP SLA?
ASR1K(config)#ip sla 101
ASR1K((config-ip-sla)# icmp-jitter ?
% Unrecognized command
ASR1K((config-ip-sla)#icmp ?
Hostname or A.B.C.D Destination IP address or hostname, broadcast disallowed
ASR1K((config-ip-sla)#?
IP SLAs entry configuration commands:
dhcp DHCP Operation
dns DNS Query Operation
ethernet Ethernet Operations
exit Exit Operation Configuration
ftp FTP Operation
http HTTP Operation
icmp-echo ICMP Echo Operation
mpls MPLS Operation
path-echo Path Discovered ICMP Echo Operation
path-jitter Path Discovered ICMP Jitter Operation
tcp-connect TCP Connect Operation
udp-echo UDP Echo Operation
udp-jitter UDP Jitter Operation
ASR1K((config-ip-sla)#path-jitter ?
Hostname or A.B.C.D Destination IP address or Hostname, broadcast disallowed
ASR1K((config-ip-sla)#path-jitter 10.1.1.38 source-ip 10.1.1.37
ASR1K#show ip sla statistics 101 details
IPSLAs Latest Operation Statistics
IPSLA operation id: 101
        Latest RTT: 19 milliseconds
Latest operation start time: 06:42:23 UTC Thu Mar 17 2022
Latest operation return code: OK
Over thresholds occurred: FALSE
---- Path Jitter Statistics ----
Hop IP 10.1.1.38:
Round Trip Time milliseconds:
        Latest RTT: 19 ms
        Number of RTT: 10
        RTT Min/Avg/Max: 19/19/20 ms
        RTT Sum/Sum2: 192/3688
Jitter time milliseconds:
        Number of jitter: 4
        Jitter Min/Avg/Max: 1/1/1 ms
        Number of positive jitter: 2
        Positive jitter Min/Avg/Max: 1/1/1 ms
        Positive jitter Number/Sum/Sum2: 2/2/2
        Number of negative jitter: 2
        Negative jitter Min/Avg/Max: 1/1/1 ms
        Negative jitter Number/Sum/Sum2: 2/2/2
Packet Values:
        Packet Loss (Timeouts): 0
        Out of Sequence: 0
        Discarded Samples: 0
Operation time to live: Forever
Operational state of entry: Active
Last time this entry was reset: Never
JimWicks
The UDP-jitter probe should work, did you have the responder setup correctly on the target-end device and check that it was receiving the UDP-probe packets (and make sure the time is sync'd between the two endpoints using NTP to avoid spurious data for RTT).
For a description of the stats, checkout the link below but in summary it's whether a received probe response had a higher or lower RTT than the previous probe.
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipsla/configuration/xe-16-8/sla-xe-16-8-book/sla-icmp-jitter.html#GUID-213F9376-194B-4E13-AB37-9B6582044329
johnlloyd_13
Level 9
Level 9
managed to fix 'udp-jitter'. you'll need to add the 'ip sla resonder' just on the remote router.
follow
