IP SLA problems
rasoftware
have this config
ip sla 1
icmp-echo 62.6.200.5
timeout 1000
threshold 2
frequency 3
ip sla schedule 1 life forever start-time now
track 100 rtr 1 reachability
ip route 0.0.0.0 0.0.0.0 "our-next-hop" track 100
ip route 0.0.0.0 0.0.0.0 Dialer0 254
ip nat inside source route-map ispA interface FastEthernet0 overload
ip nat inside source route-map ispB interface Dialer0 overload
access-list 40 remark IPs for NAT policy
access-list 40 permit 192.0.0.0 0.255.255.255
access-list 101 permit icmp any host 62.6.200.5 echo
route-map LOCAL_POLICY permit 10
match ip address 101
set interface FastEthernet0
route-map ispB permit 10
match ip address 40
match interface Dialer0
route-map ispA permit 10
match ip address 40
match interface FastEthernet0
The track doesn seem to work, when I have default route to metric 1 and no track it works.
I have this config working where I have two DSL ports but this has 1 DSL and 1 FE.
Will this work?
30 Replies 30
I have a problem with my IP sla on a router with two ISPs (ISP A and ISP B). A= boradband, B= T1. I have tested the failover in the past by disabling the primary interface and it worked. Yesterday ISP A went down partially and the failover to T1 didin't happened. Maybe because the tracking was done on ISP A gateway and that IP was reachable even though the ISP A was down.
I have made some modification to my config to see if I can fix this, but it looks like unless I specify a static default route with no tracking option to my ISP A, the traffic keep going through T1.  In my current config, I have added an "P local Policy Route-MAP" and I also changed the IP being tracked to my ISP's DNS address.
Someone please review my attached config and advise what is wrong with my config. Thanks,
Shuja
term len 0
TQI-WN-RT2911#sh run
Building configuration...
Current configuration : 7720 bytes
! Last configuration change at 20:54:18 UTC Sun Oct 28 2012 by admin
! NVRAM config last updated at 20:54:18 UTC Sun Oct 28 2012 by admin
version 15.1
service password-encryption
hostname TQI-WN-RT2911
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa authorization network default local
aaa session-id common
no ipv6 cef
ip source-route
ip cef
ip dhcp remember
ip domain name TQI.com
crypto pki trustpoint TP-self-signed-2562258950
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2562258950
revocation-check none
rsakeypair TP-self-signed-2562258950
crypto pki certificate chain TP-self-signed-2562258950
certificate self-signed 01
  3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32353632 32353839 3530301E 170D3131 30393236 32333335
  34375A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 35363232
  35383935 3030819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100E64D 71673902 BC3D62F5 56A26C5D 1FC393A5 1B44B7E9 8B248303 B3DC089E
  30D8E3BD 4965B46B 4495F49D CB63CFC3 D14E8C0E 318C02B6 FBEBCC2A ED275932
  2EAC8476 A6B134B4 1B9371F3 C91470AE 1D8C4DC6 570050BD 97891569 D197CA39
  D4CCDA38 7572410C C36C35AF E87F4811 15E9E9D4 7D980BBA 0B5C882F 21DFC91E
  8C030203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
  551D2304 18301680 1490A807 266EC76C FFC7030F 42BB3049 4BEC91AC EC301D06
  03551D0E 04160414 90A80726 6EC76CFF C7030F42 BB30494B EC91ACEC 300D0609
  2A864886 F70D0101 05050003 81810003 B0DF4CC1 FB0E7E0C 59E37631 74C56079
  020EA9A3 0E81E811 AA964452 886FA451 45700D11 5C148D20 F4C2628E 272BA7A6
  95D4DBAA 259E9441 C4F8BD49 C293B9B3 5C24C5E2 D2DE97F9 0229C07D 91D2D6D0
  151C80B0 A0875447 ABC4642F 25278066 9D7F0E6F 8020EA95 902D1423 FAA386D9
  ECCAB08C F6B56855 FA0654EF 612BDB
            quit
username admin privilege 15 password 7 141F13050806sdfds25242F
redundancy
track 1 ip sla 1 reachability
delay down 10 up 20
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key ############ address 173.161.255.241 255.255.255.240
crypto isakmp client configuration group EASY_VPN
key $#############
dns 10.10.0.241 10.0.0.241
domain ttqi.com
pool EZVPN-POOL
acl VPN+ENVYPTED_TRAFFIC
save-password
max-users 50
max-logins 10
netmask 255.255.255.0
crypto isakmp profile EASY_VPN_IKE_PROFILE1
   match identity group EASY_VPN
   client authentication list default
   isakmp authorization list default
   client configuration address respond
   virtual-template 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile EASY_VPN_IPSec_PROFILE1
set security-association idle-time 86400
set transform-set ESP-3DES-SHA
set isakmp-profile EASY_VPN_IKE_PROFILE1
crypto map VPN_TUNNEL 10 ipsec-isakmp
description ***TUNNEL-TO-FAIRFIELD***
set peer 173.161.255.241
match address 105
interface Loopback1
ip address 10.10.30.1 255.255.255.0
interface Tunnel1
ip address 172.16.0.2 255.255.255.0
ip mtu 1420
tunnel source GigabitEthernet0/0
tunnel destination 173.161.255.241
tunnel path-mtu-discovery
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description Optonline  WAN secondary
ip address 108.58.179.205 255.255.255.248 secondary
ip address 108.58.179.202 255.255.255.248
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
description T1 WAN Link
ip address 64.7.17.100 255.255.255.240
ip nat outside
duplex auto
speed auto
interface GigabitEthernet0/2
description LAN
ip address 10.10.0.1 255.255.255.0 secondary
ip address 10.10.0.3 255.255.255.0
ip nat inside
duplex auto
speed auto
interface Virtual-Template1 type tunnel
ip unnumbered Loopback1
tunnel mode ipsec ipv4
tunnel protection ipsec profile EASY_VPN_IPSec_PROFILE1
router eigrp 1
network 10.10.0.0 0.0.0.255
network 10.10.30.0 0.0.0.255
network 172.16.0.0 0.0.0.255
router odr
router bgp 100
bgp log-neighbor-changes
ip local policy route-map IP-SLA-ROUTE-POLICY
ip local pool EZVPN-POOL 10.10.30.51 10.10.30.199 recycle delay 65535
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source route-map OPTIMUM-ISP interface GigabitEthernet0/0 overload
ip nat inside source route-map T1-ISP interface GigabitEthernet0/1 overload
ip nat inside source static tcp 10.10.0.220 3389 64.7.17.100 3389 extendable
ip nat inside source static tcp 10.10.0.243 25 108.58.179.202 25 extendable
ip nat inside source static tcp 10.10.0.243 80 108.58.179.202 80 extendable
ip nat inside source static tcp 10.10.0.243 443 108.58.179.202 443 extendable
ip nat inside source static tcp 10.10.0.220 3389 108.58.179.202 3389 extendable
ip nat inside source static tcp 10.10.0.17 12000 108.58.179.202 12000 extendable
ip nat inside source static tcp 10.10.0.16 80 108.58.179.205 80 extendable
ip nat inside source static tcp 10.10.0.16 443 108.58.179.205 443 extendable
ip nat inside source static tcp 10.10.0.16 3389 108.58.179.205 3389 extendable
ip route 0.0.0.0 0.0.0.0 108.58.179.201 track 1
ip route 0.0.0.0 0.0.0.0 64.7.17.97 100
ip access-list extended VPN+ENVYPTED_TRAFFIC
permit ip 10.10.0.0 0.0.0.255 any
permit ip 10.0.0.0 0.0.0.255 any
permit ip 10.10.30.0 0.0.0.255 any
ip sla 1
icmp-echo 167.206.112.138 source-interface GigabitEthernet0/0
threshold 100
timeout 200
frequency 3
access-list 1 permit 10.10.0.0 0.0.0.255
access-list 2 permit 10.10.0.0 0.0.0.255
access-list 100 permit ip 10.10.0.0 0.0.0.255 any
access-list 101 permit icmp any host 167.206.112.138 echo
access-list 105 remark ***GRE-TRAFFIC TO FAIRFIELD***
access-list 105 permit gre host 108.58.179.202 host 173.161.255.241
route-map T1-ISP permit 10
match ip address 100
match interface GigabitEthernet0/1
route-map OPTIMUM-ISP permit 10
match interface GigabitEthernet0/0
route-map IP-SLA-ROUTE-POLICY permit 10
set ip next-hop 108.58.179.201
set interface Null0
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
privilege level 15
transport input telnet ssh
line vty 5 15
privilege level 15
scheduler allocate 20000 1000
end
TQI-WN-RT2911#
