Bandwidth Management - Best Way
JohnTylerPearce
Level 7
Level 7
I need to rephrase this question. Let's say we have 100Mbps WAN link to the ISP, we have CustomerA
and then the rest of our Customers. We want CustomerA to have lower priority than everyone else over
the WAN links. What is the best way to configure this?
Here is a simple ntwork diagram.
CoreSwitch -----> Core Router -----> ISP
I would like to implement this at the link at the core router receiving traffic from the CoreSwitch.
Would the following work.
access-list CustomerA permit ip (CustomerA Networks)
access-list CustomerBZ (Everyone Else)
class-map CustomerA
match access-group CustomerA
class-map CustomerBZ
match access-group CustomerBZ
My problem is after this I'm not sure the best route to take. I don't want to nessarily rate-limit traffic, but just give all of our customers
higher priority over CustomerA.
Edison Ortiz
You can configured CBWFQ for class CustomerBZ to be 85% or more. This will guarantee the flows for that class and the remaining % will be allocated to class class-default which by process of elimination will be CustomerA.
Edison
Edison Ortiz
Edison
