05-28-2014 05:45 AM - edited 03-04-2019 11:03 PM
I have set up two 3925 in a hot-standby configuration.
If i configure track with IP SLA, the IP SLA stops probing (ping) as soon as at least one interface goes to standby. IP SLA probes are declared Down.
If all standby interfaces go to Active (by manipulating priority or turning off the other router), the IP SLA ping probes start again.
I have not seen this described as intended behavior, feature, or caveat. Is it likely to be a bug in this particular IOS version?
IOS version is 15.3(3)M2 (with technology/license: ipbasek9, securityk9, and uck9)
Svein
05-29-2014 10:03 PM
please share your HSRP & IP SLA config :)
if you using track command on HSRP, you should define command 'preempt' both of HSRP (active/standby)
06-02-2014 04:51 AM
Below is my HSRP and IP SLA config.
HSRP with preemption is working, except for the intended ip sla priority manipulation.
The problem is only that IP SLA stops sending out PING probes and declares Down state when one or more HSRP interfaces go to standby. This even if the IP SLA is totally unrelated to the HSRP tracking.
Config for the normally standby router (the other has slightly higher standby pri):
interface Vlan10
description Internal net
ip address 172.24.1.202 255.255.240.0
standby 1 ip 172.24.1.200
standby 1 priority 100
standby 1 preempt
standby 1 name HSRP1
standby 1 track 1 decrement 10
standby 1 track 2 decrement 10
interface Vlan20
description Outside net
ip address 10.5.1.102 255.255.255.0
standby 2 ip 10.5.1.100
standby 2 priority 100
standby 2 preempt
standby 2 name HSRP2
standby 2 track 1 decrement 10
standby 2 track 2 decrement 10
track 1 ip sla 11 reachability
track 2 ip sla 12 reachability
ip sla 11
icmp-echo 172.24.1.1
timeout 5000
frequency 10
threshold 500
ip sla schedule 11 start-time now life forever
ip sla 12
icmp-echo 10.5.1.201
timeout 5000
frequency 10
threshold 500
ip sla schedule 12 start-time now life forever
sbc02#show stand bri P indicates configured to preempt. | Interface Grp Pri P State Active Standby Virtual IP Vl10 1 80 P Standby 172.24.1.201 local 172.24.1.200 Vl20 2 80 P Standby 10.5.1.101 local 10.5.1.100 sbc02#show ip sla summ IPSLAs Latest Operation Summary Codes: * active, ^ inactive, ~ pending ID Type Destination Stats Return Last (ms) Code Run ----------------------------------------------------------------------- *11 icmp-echo 172.24.1.1 - Unknown - *12 icmp-echo 10.5.1.201 - Unknown -
If I do a shutdown of Vlan10 and Vlan20 and then "no shut", the IP SLA kicks back into action.
06-02-2014 09:30 AM
Hello
Is just one rtr acting the primary for both vlans - Does this router has its priority set higher than the default 100 as shown in you post?
I would first make the primary rtr have a higher priority value than the HSRP default
res
Paul
06-02-2014 08:50 PM
check this article 'Tracking using IP SLA'
you should define source-ip or source-interface to starts IP SLA.
and make sure the routing protocol able to reach the IP Address for icmp-echo
06-06-2014 04:20 AM
I have checked and double checked all your suggestions.
The strange thing is that ANY ip sla probing stops, even to an internal interface, when HSRP interface(s) go to standby state.
I have now tried with a different IOS version: 15.2(4)M6, but still with the same result.
06-10-2014 06:46 AM
I think I am on to something:
If I remove the redundancy inter-device configuration from at least one of the routers, the ip sla works as expected.
DELETED:redundancy inter-deviceDELETED:scheme standby HSRP1! redundancy ! ! ipc zone default association 1 no shutdown protocol sctp local-port 5005 local-ip 172.24.1.202 remote-port 5005 remote-ip 172.24.1.201
With this change, the IP SLA and HSRP failover work OK, but I am unsure of what effect it may have on stateful failover for SIP VOIP connections.
