IP SLA to perform failover, but can't fail back because of NAT entries?
ejensenscs
I'm trying to set up a router with 2 WANs and use SLA to failover the traffic.  There is no static NAT, just the dynamic NAT(pat).  I want to have traffic bound for one destination use WAN B and all other internet traffic use WAN A.  So the SLA is using ping to hit the gateway on both WANs and failover the traffic from one to the other when it goes down.  It works perfectly.  The problem is the failback.  I plug the 'down' wan back in and the SLA comes up and the routes fail over.  When I do the failover of WAN A it works, but doesn't fail back when WAN A comes back up.  When I get on the router and run
clear ip nat trans *
everything comes back up right away.   This is a 861 router with version c860-universalk9-mz.124-24.T5.bin
What can I do to clear out the NAT automatically?
or Can I put a command in the SLA config to issue that
command?
track 101 ip sla 1 reachability
track 102 ip sla 2 reachability
ip route 0.0.0.0 0.0.0.0 100.1.1.1 track 101
ip route 209.209.209.209 255.255.255.255 200.1.1.1 track 102
ip route 0.0.0.0 0.0.0.0 200.1.1.1 10 track 102
ip sla 1
icmp-echo 100.1.1.1 source-ip 100.1.1.2
threshold 3
frequency 5
ip sla schedule 1 start-time now
ip sla 2
icmp-echo 200.1.1.1 source-ip 200.1.1.2
threshold 3
frequency 5
ip sla schedule 2 start-time now
ip sla enable reaction-alerts
Your config looks fine.  2 options that i can find
1) change the nat timeout per protocol as you see fit for your network & let traffic naturally failback on its own as the entries timeout.  Nat translations only timeout if they arent used (by default 24 hours) so you wont be interrupting any traffic IF your nat timeouts are longer than any protocol/connection keepalives you might have on your network
          Pros:  nobodies traffic is disconnected since you arent manually clearing the nat table.  Cons:  you dont have instant failover that you want
see command,
ip nat translation timeout
http://www.cisco.com/en/US/docs/ios/ipaddr/configuration/guide/iadnat_addr_consv_ps6350_TSD_Products_Configuration_Guide_Chapter.html#wp1056211
2) An EEM/Tcl script could be used to automatically execute the command when matching specific criteria.  Criteria could be something basic like, When interfaceX goes up/up execute command
clear ip nat trans
I believe there is a running eem/tcl topic somewhere in these cisco forums
          Pros: instant failover & You dont have to touch the router for this issue again. Cons:  you might interrupt some peoples connections/traffic.
see eem/tcl sections
http://www.cisco.com/en/US/docs/ios/netmgmt/configuration/guide/12_4t/nm_12_4t_book.html
9 Replies 9
Michael Couture
When the link comes back up is the route populated back into the routing table? And what do you have for a NAT statement?
The route statements disappear from the
show ip route
output correctly.  The traffic routes correctly, the ip SLA is working just fine.  It's the NAT part that is sticking....
Everything works after fail or failback as soon as I issue the
clear ip nat trans*
command.
ip nat inside source route-map priISP interface Vlan3 overload
ip nat inside source route-map secISP interface FastEthernet4 overload
route-map priISP permit 10
match ip address 103
match interface Vlan3
route-map secISP permit 10
match interface FastEthernet4
access-list 103 permit ip 192.168.1.0 0.0.0.255 any
Please change this and try...
delay down 10 up 10
ip sla 1
timeout 20000
threshold 3
frequency 5
Remove this lines...
ip sla 2
threshold 3
frequency 5
Let me know the results
thanks
Rizwan Rafeek
If I take out the route statement, my traffic goes all on the WAN 1... which defeats my whole purpose of the project.
I need more than just the primary wan failover, I need the second wan to failover to the primary wan if that goes down also.  It does work this way too, so it seems possible.  My problem seems to be all related to NAT.  When I test the failover of each WAN it fails over correctly.
After I fail the secondary wan, I can clear the NAT table and it works.  Then I fail it back, links come up, clear the NAT and traffic flows properly again.  If I fail the primary WAN the main traffic switches over (after clearing the NAT), the little bit of secondary traffic never stops because that link didn't fail and the NAT doesn't need to be cleared.  After the primary comes up, the general traffic fails just like always, until I enter
and then we're back to square one and everything is working fine.
Can IP SLA issue a
custom
command after an action like packetloss or icmp fail?
Check your outside interfaces and make sure IP NAT OUTSIDE is assigned to both of them. I ran a simulation and the only way I was able to replicate the problem you are describing is when I had only one of the outside interfaces configured as an IP NAT outside interface.
Yes, NAT outside is on both interfaces.  I think everybody is missing the fact that this works in everyway I want it to, but requires a small amount of manual intervention (getting on the console and issuing the
command).
If I clear out the existing NAT table, the traffic starts using the next interface just fine, but I have to manually clear out the table.  If I bring the NAT timeout to a really small number, I think that would disrupt normal traffic by resetting the connections too frequently when no failover conditions are needed.  For example, if you clear out a NAT table, some Remote Desktop connections will disconnect and reconnect.  Happens automatically, but if it was constantly happening all day it would be bad.  So I feel like the NAT timeout is not the answer.
see command,
clear ip nat trans
Nicholas May!  Scripting was the answer, I don't think I even knew that existed!  I have a working solution, when the SLA takes a route down or out, the NAT table gets cleared and traffic gets reestablished with changed routes.  Then when it comes back up, the NAT table gets cleared again and traffic is balanced out again.  I used the track state "any" instead of up or down so it runs on an up or a down state change.  I'm pretty impressed at how seemless this works now.  I think the last tweak will be to take the sensetivity down a bit, allow more missed pings, etc.  That way it won't flip flop all day.
Here's the code I used:  (needed 2 instances to watch the 2 SLA tracks)
event manager applet clear_nat_1
event track 101 state any
action 0.0 cli command "enable"
action 1.0 cli command "clear ip nat trans *"
action 3.0 syslog msg "WAN failover, cleared NAT"
event manager applet clear_nat_2
event track 102 state any
When running a constant ping during failover it drops out and doesnt come back unless i issue the
statement manually.  Is it because the enable account requires a password?
Here is what I have:
track 1 ip sla 1 reachability
ip route 0.0.0.0 0.0.0.0 x.x.x.x track 1
ip route 0.0.0.0 0.0.0.0 x.x.x.x 10
ip sla 1
icmp-echo 4.2.2.2 source-interface GigabitEthernet0/0
frequency 5000
ip sla schedule 1 life forever start-time now
route-map internet-2 permit 10
match ip address internet
match interface GigabitEthernet0/1
route-map internet permit 1
match interface GigabitEthernet0/0
event manager applet NAT_CLEAR
event track 1 state any
action 3.0 syslog msg "FAIL OVER JUST OCCURED"
Thanks for all your insight!
