IP SLA
Kurt Warner
We have had to add an additional firewall due to high usage. We set up IP SLA  and the load has been split across the two links and this has been working ( for the most part).  I need all traffic from  10.1.1.x  to go out track 1 . I tried adding a route
ip route 10.1.1.0  0.0.0.255 192.168.1.2 track 1 ( said inconsitant mask)
then
ip route 10.1.1.0  255.255.255.0 192.168.1.2 track 1 ( stopped all data flowing)
current working config
ip route 0.0.0.0 0.0.0.0 192.168.1.2 track 1
ip route 0.0.0.0 0.0.0.0 192.168.1.3 track 2
ip route 8.8.4.4 255.255.255.255 192.168.1.3
ip route 8.8.8.8 255.255.255.255 192.168.1.2
ip sla 1
icmp-echo 8.8.8.8
threshold 100
frequency 5
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 8.8.4.4
threshold 100
frequency 5
ip sla schedule 2 life forever start-time now
any ideas?
Seb Rupik
Hi there,
I think you are getting the usage of the route statement confused. A route statement specifies the next-hop for a destination prefix, not the source.
If you want to control the traffic based on the source of the traffic then you need to look at Policy Based Routing. Something like this:
access-list 10 permit ip 10.1.1.0 255.255.255.0 any
int gi0/1
  ip policy route-map PRB01
route-map PBR01 permit 10
  match ip address 10
  set ip next-hop 192.168.1.2
...where gi0/1 is the ingress interface for the traffic flows from 10.1.1.0/24.
cheers,
Seb.
Seb Rupik
Hi there,
int gi0/1
  match ip address 10
cheers,
Seb.
This worked !!!
access-list 101 permit ip 10.1.1.0 0.0.0.255 any  ( wild card mask)
match ip address 101
int g0/1
ip policy route-map PBR01
Kurt Warner
So if i added that to the interface g0/1 only traffic from 10.1.1.0/24 could use that interface?
No, any traffic could use it but only traffic with a source IP in the 10.1.1.0/24 subnet would be policy routed, the rest would just use the normal routing table.
Jon
