IP SLAs-Using the ICMP Echo problem
ndarawsheh
I have 2 ISP connections I am using NAT for load balancing and fail over
here is a sample config:
interface FastEthernet0/1
description $ISP1-WAN$
ip dhcp client route track 123
ip address dhcp client-id FastEthernet0/1
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/0
description $ISP2-WAN$
ip dhcp client route track 345
ip address dhcp client-id FastEthernet0/0
ip nat outside
duplex auto
speed auto
interface FastEthernet1/1
description $LAN$
ip nat inside
duplex auto
speed auto
track timer interface 5
track 123 rtr 1 reachability
delay down 15 up 10
track 345 rtr 2 reachability
delay down 15 up 10
ip nat inside source route-map ISP1 interface FastEthernet0/1 overload
ip nat inside source route-map ISP2 interface FastEthernet0/0 overload
access-list 110 permit ip 192.168.1.0 0.0.0.255 any
access-list 122 permit icmp 172.168.0.0 0.0.255.255 any echo
access-list 133 permit icmp 10.10.10.0 0.0.0.255 any echo
!route map for NAT
route-map ISP1 permit 10
match ip address 110
match interface FastEthernet0/1
route-map ISP2 permit 10
match interface FastEthernet0/0
!route map for local traffic
route-map INTERNET-REACHABILITY permit 10
match ip address 122
set interface FastEthernet0/1
route-map INTERNET-REACHABILITY permit 20
match ip address 133
set interface FastEthernet0/0
ip local policy route-map INTERNET-REACHABILITY
up to this stage every thing is working fine, 2 default routes are present in the routing table, NAT is load balancing between the 2 connections and fail over is working and I can ping internet addresses using source interfaces fast0/0 and fast 0/1
#show ip route track-table
ip route 0.0.0.0 0.0.0.0 172.168.0.1 254 track 123 state is [up]
ip route 0.0.0.0 0.0.0.0 10.10.10.1 254 track 345 state is [up]
now the problem is when I add SLAs using ICMP echo config to track the ISP reachability to the internet the two objects goes down and the default routes removed from the thr routing table.
here is the config
ip sla monitor 1
type echo protocol ipIcmpEcho 66.102.11.104 source-interface FastEthernet0/1
timeout 1000
threshold 40
frequency 3
ip sla schedulw 1 life forever start-time not
ip sla monitor 2
type echo protocol ipIcmpEcho 66.102.11.104 source-interface FastEthernet0/0
timeout 1000
threshold 40
frequency 3
ip sla schedulw 2 life forever start-time not
ip route 0.0.0.0 0.0.0.0 172.168.0.1 254 track 123 state is [down]
ip route 0.0.0.0 0.0.0.0 10.10.10.1 254 track 345 state is [down]
from debug
the router manages to send the packets out using the right interfaces but reply from google times out, tried different address including ISP gateways and dns servers with same results
I tried different timeout and frequency settings even at some stage i did not use the optional commands to setup timeout and freq and still same results, again once I remove the SLAs config i can ping using the interfaces f0/0 and f0/1 as source .
any help please please
ndarawsheh
any body
