IP static routing issue
R Manjunatha
Level 3
Level 3
HI,
I can ping the IP address192.168.29.105 of the vManage controller from the internet router but I am unable to ping from vEdge2 router. I confirmed the default route towards the internet router ip route 0.0.0.0/0 70.1.1.13.
Internet router
Verizon-Internet#ping 192.168.29.105
Sending 5, 100-byte ICMP Echos to 192.168.29.105, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/43/138 ms
configuration
interface Ethernet0/0
ip address 70.1.1.1 255.255.255.252
duplex auto
interface Ethernet2/0
ip address 80.1.1.2 255.255.255.252
duplex auto
interface Ethernet2/1
ip address 70.1.1.13 255.255.255.252
duplex auto
interface Ethernet2/2
ip address 70.1.1.9 255.255.255.252
duplex auto
interface Ethernet2/3
ip address 70.1.1.5 255.255.255.252
duplex auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 80.1.1.1 name towards-Core-Router
vEdge2- configuration
vEdge2# ping 192.168.29.105
Ping in VPN 0
PING 192.168.29.105 (192.168.29.105) 56(84) bytes of data.
^C
--- 192.168.29.105 ping statistics ---
8 packets transmitted, 0 received, 100% packet loss, time 7205ms
interface ge0/0
description "CONNECT TO MPLS"
ip address 60.1.1.14/30
tunnel-interface
encapsulation ipsec
color mpls
allow-service bgp
allow-service dhcp
allow-service dns
allow-service icmp
allow-service sshd
allow-service netconf
allow-service ntp
allow-service ospf
no allow-service stun
allow-service https
no shutdown
interface ge0/1
description "CONNECTED TO INTERNET"
ip address 70.1.1.14/30
tunnel-interface
encapsulation ipsec
color biz-internet
allow-service bgp
allow-service dhcp
allow-service dns
allow-service icmp
allow-service sshd
allow-service ntp
allow-service ospf
allow-service https
no shutdown
vpn 100
name service-VPN
router
ospf
timers spf 200 1000 10000
redistribute omp
area 0
interface ge0/2
exit
exit
interface ge0/2
description vpn100-internal-LAN
ip address 20.1.1.1/30
no shutdown
vpn 512
name Mgnt-VPN512
interface eth0
description Magnt-VPN512-Interface
ip dhcp-client
no shutdown
6 Replies 6
Just check cable and interface between vedge and internet router are it correct or not
Config is OK
I do not see that either device has any interface in 192.168.anything or any route for 192.168.anything so I do not understand how any ping works.
Rick
all SD-WAN controllers are installed in hypervisor Esxi and there is a communication with pnetlab
connections are correct and it's ping internet gateway.
vEdge2# ping 70.1.1.13
Ping in VPN 0
PING 70.1.1.13 (70.1.1.13) 56(84) bytes of data.
64 bytes from 70.1.1.13: icmp_seq=1 ttl=255 time=20.9 ms
64 bytes from 70.1.1.13: icmp_seq=2 ttl=255 time=13.1 ms
64 bytes from 70.1.1.13: icmp_seq=3 ttl=255 time=9.32 ms
64 bytes from 70.1.1.13: icmp_seq=4 ttl=255 time=21.1 ms
64 bytes from 70.1.1.13: icmp_seq=5 ttl=255 time=16.9 ms
ping 192.168.29.105 source 70.1.1.14
Hi @R Manjunatha
 As per the logs, the ping is trying to reach using vlan0
Ping in VPN 0
But, this should be management traffic, right? Probably you are trying to join the cEdge to the vManage. It should go to Vlan 512
  • VPN 0—Transport VPN, which carries control traffic via the configured WAN transport interfaces. Initially, VPN 0 contains all of a device's interfaces except for the management interface, and all interfaces are disabled.
  • VPN 512—Management VPN, which carries out-of-band network management traffic among the Viptela devices in the overlay network. The interface used for management traffic resides in VPN 512. By default, VPN 512 is configured and enabled on all vEdge routers except for vEdge 100. For controller devices, by default, VPN 512 is not configured.
