Can't access the internet from my vlan router 1921
Jaskaran B
Hello, I'm having connectivity issue's with my router and switch.
I'm unable, from the 1921 router ping my computer which is in a vlan, without taking the firewall offline.
I'm also unable to ping the internet from the computer on the vlan, but I can ping the internet from the router.
I'm able to ping both sides of my vlan's on the sub interfaces though.
Router#sh ip int br
Embedded-Service-Engine0/0 unassigned YES NVRAM administratively down down
GigabitEthernet0/0 192.15.10.1 YES NVRAM up up
GigabitEthernet0/0.1 192.10.5.1 YES NVRAM up up
GigabitEthernet0/0.2 172.8.10.1 YES NVRAM up up
GigabitEthernet0/1 10.0.0.2 YES NVRAM up up
Serial0/1/0 unassigned YES NVRAM administratively down down
NVI0 192.15.10.1 YES unset up up
Router#sh ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
+ - replicated route, % - next hop override
Gateway of last resort is 10.0.0.1 to network 0.0.0.0
S* 0.0.0.0/0 [1/0] via 10.0.0.1
10.0.0.0/8 is variably subnetted, 4 subnets, 2 masks
C 10.0.0.0/24 is directly connected, GigabitEthernet0/1
L 10.0.0.2/32 is directly connected, GigabitEthernet0/1
L 10.0.0.20/32 is directly connected, GigabitEthernet0/1
L 10.0.0.30/32 is directly connected, GigabitEthernet0/1
172.8.0.0/16 is variably subnetted, 2 subnets, 2 masks
C 172.8.0.0/16 is directly connected, GigabitEthernet0/0.2
L 172.8.10.1/32 is directly connected, GigabitEthernet0/0.2
192.10.5.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.10.5.0/24 is directly connected, GigabitEthernet0/0.1
L 192.10.5.1/32 is directly connected, GigabitEthernet0/0.1
192.15.10.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.15.10.0/30 is directly connected, GigabitEthernet0/0
L 192.15.10.1/32 is directly connected, GigabitEthernet0/0
7 Replies 7
M02@rt37
Hello @Jaskaran B,
It seems that Router on A Stick is configured on your 1921.
Do the VLAN ping their own Gateway?
Please share the 1921 config.
Thanks.
Best regards
Pinging 192.10.5.1 with 32 bytes of data:
Reply from 192.10.5.1: bytes=32 time<1ms TTL=255
Ping statistics for 192.10.5.1:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 192.15.10.1 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 10
ip address 192.10.5.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface GigabitEthernet0/0.2
encapsulation dot1Q 20
ip address 172.8.10.1 255.255.0.0
ip nat inside
interface GigabitEthernet0/1
ip address 10.0.0.2 255.255.255.0
ip nat outside
duplex auto
speed auto
interface Serial0/1/0
no ip address
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source static 192.10.5.10 10.0.0.20
ip nat inside source static 172.8.10.5 10.0.0.30
ip route 0.0.0.0 0.0.0.0 10.0.0.1
Thanks for the config @Jaskaran B
Check you ACL. Two IP only NATed?
Best regards
Jaskaran B
Router#sh running-config
Building configuration...
Current configuration : 1708 bytes
! Last configuration change at 13:06:06 UTC Sat Jul 29 2023
version 15.2
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
license udi pid CISCO1921/K9 sn FGL1831239H
license accept end user agreement
redundancy
no ip address
shutdown
duplex auto
speed auto
ip nat inside
ip nat inside
ip nat outside
duplex auto
speed auto
no ip address
shutdown
no ip http server
control-plane
line con 0
login
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input all
scheduler allocate 20000 1000
end
Jaskaran B
Pro Inside global Inside local Outside local Outside global
--- 10.0.0.30 172.8.10.5 --- ---
--- 10.0.0.20 192.10.5.10 --- ---
Hi @Jaskaran B
 Disable the firewall on the machine to reply ping is expected. Unless you config the firewall do allow icmp.
Now, the way your router is configured, only 2 IPs is able to access the internet. You should have a config like this
Ip nat inside source list  100 interface  GigabitEthernet0/1 overload
Ip access-list extend 100
Permit  192.10.0.0 0.0.255.255 any
Permit 172.8.0.0 0.0..255.255 any
And remove IP from interface GigabitEthernet0/0
Interface GigabitEthernet0/0
no ip add
