ip unnumbered tunnel command
rll3
does anyone know what the tunnel interface number is with the following command? Like, would it represent a predefined vlan or something like that?
6513(config-subif)#ip unnumbered tunnel ?
<0-2147483647> Tunnel interface number
paolo bevilacqua
No. Tunnels interfaces can have a arbitrary ID and that is what the CLI is telling you.
It is not common design to have 802.1q interfaces to be unnumbered, let alone from a tunnel interface.
Thanks for the insight... what i'm trying to do is tunnel l2 to l3 traffic on a cat6500. would this ip ... command help me?
