ip verify unicast reverse-path
ajf303
can anyone explain about  "ip verify unicast reverse-path" and when we could use this...
InayathUlla Sharieff
Good explanation down here:
Use the ip verify unicast reverse-path interface command to mitigate problems caused by malformed or forged (spoofed) IP source addresses that pass through a router. Malformed or forged source addresses can indicate denial-of-service (DoS) attacks based on source IP address spoofing.
When Unicast RPF is enabled on an interface, the router examines all packets received on that interface. The router checks to make sure that the source address appears in the routing table and matches the interface on which the packet was received. This "look backwards" ability is available only when Cisco Express Forwarding (CEF) is enabled on the router because the lookup relies on the presence of the Forwarding Information Base (FIB). CEF generates the FIB as part of its operation.
Note Unicast RPF is an input function and is applied only on the input interface of a router at the upstream end of a connection.
The Unicast Reverse Path Forwarding feature checks to see if any packet received at a router interface arrives on one of the best return paths to the source of the packet. The feature does this by doing a reverse lookup in the CEF table. If Unicast RPF does not find a reverse path for the packet, Unicast RPF can drop or forward the packet, depending on whether an ACL is specified in the Unicast Reverse Path Forwarding command. If an ACL is specified in the command, then when (and only when) a packet fails the Unicast RPF check, the ACL is checked to see if the packet should be dropped (using a deny statement in the ACL) or forwarded (using a permit statement in the ACL). Whether a packet is dropped or forwarded, the packet is counted in the global IP traffic statistics for Unicast RPF drops and in the interface statistics for Unicast RPF.
If no ACL is specified in the Unicast Reverse Path Forwarding command, the router drops the forged or malformed packet immediately and no ACL logging occurs. The router and interface Unicast RPF counters are updated.
Unicast RPF events can be logged by specifying the logging option for the ACL entries used by the Unicast Reverse Path Forwarding command. Log information can be used to gather information about the attack, such as source address, time, and so on.
Note With Unicast RPF, all equal-cost "best" return paths are considered valid. This means that Unicast RPF works in cases where multiple return paths exist, provided that each path is equal to the others in terms of the routing cost (number of hops, weights, and so on) and as long as the route is in the FIB. Unicast RPF also functions where Enhanced Internet Gateway Routing Protocol (EIGRP) variants are being used and unequal candidate paths back to the source IP address exist.
To use Unicast RPF, enable CEF switching or distributed CEF (dCEF) switching in the router. There is no need to configure the input interface for CEF switching. As long as CEF is running on the router, individual interfaces can be configured with other switching modes.
Note It is very important for CEF to be configured globally in the router. Unicast RPF will not work without CEF.
Unicast RPF should not be used on interfaces that are internal to the network. Internal interfaces are likely to have routing asymmetry, meaning that there are multiple routes to the source of a packet. Unicast RPF should be applied only where there is natural or configured symmetry.
For example, routers at the edge of the network of an Internet service provider (ISP) are more likely to have symmetrical reverse paths than routers that are in the core of the ISP network. Routers that are in the core of the ISP network have no guarantee that the best forwarding path out of the router will be the path selected for packets returning to the router. Hence, it is not recommended that you apply Unicast RPF where there is a chance of asymmetric routing. It is simplest to place Unicast RPF only at the edge of a network or, for an ISP, at the customer edge of the network.
Examples
The following example shows enabling the Unicast Reverse Path Forwarding feature on a serial interface:
ip cef
! or "ip cef distributed" for RSP+VIP based routers
interface serial 5/0/0
Ref:http://www.cisco.com/en/US/docs/ios/12_2/security/command/reference/srfrpf.html
Inayath
Another link;
http://www.ciscopress.com/articles/article.asp?p=1725270
TH
Inayath
***********Plz rate all usefull posts***************
Normally when your router receives unicast IP packets it only cares about one thing:
  • What is the destination IP address of this IP packet so I can forward it?
If the IP packet has to be routed it willl check the routing table for the destination IP address, select the correct interface and it will be forwarded. Your router really doesn’t care about source IP addresses as it’s not important for forwarding decisions.
Because the router doesn’t check the source IP address it is possible for attackers to spoof the source IP address and send packets that normally might have been dropped by the firewall or an access-list.
uRPF is a security feature that prevents these spoofing attacks. Whenever your router receives an IP packet it will check if it has a matching entry in the routing table for the source IP address. If it doesn’t match, the packet will be discarded. uRPF has two modes:
  • Strict mode
  • Loose mode
Let’s take a look at the difference between both modes and how to configure them.
Strict Mode
Strict mode means that that router will perform two checks for all incoming packets on a certain interface:
  • Do I have a matching entry for the source in the routing table?
  • Do I use the same interface to reach this source as where I received this packet on?
When the incoming IP packets passes both checks, it will be permitted. Otherwise it will be dropped. This is perfectly fine for  IGP routing protocols since they use the shortest path to the source of IP packets. The interface that you use to reach the source will be the same as the interface where you will receive the packets on.
Commands
Router(config)#interface fastEthernet 0/0
Router(config-if)#ip verify unicast source reachable-via rx
Loose Mode
Loose mode means that the router will perform only a single check when it receives an IP packet on an interface:
When it passed this check, the packet is permitted. It doesn’t matter if we use this interface to reach the source or not. Loose mode is useful when you are connected to more than one ISP and you use asymmetric routing.The only exception is the null0 interface, if you have any sources with the null0 interface as the outgoing interface then the packets will be dropped
Commands
Router(config-if)#ip verify unicast source reachable-via any
Additional Features
  • Logging and Exemptions: uRPF allows the usage of an access-list so you can decide what sources it should check and if required, log the packets that are dropped using access-list logging.
  • Self-pinging: Allow the router to ping itself using uRPF strict mode on the interface.
  • Default route: You can configure uRPF to check source IP addresses against a default route. You can use this when you want to accept all packets from your internet connection while protecting yourself against spoofed packets with source IP address from your internal network.
