How to add an additional WIC
We have a cisco 2811 running 12.4(23b) IOS version. We have recently added a T1 to created a bonded T1 (3MB serial link) and I'm trying to add an additional WIC to our router. The WIC is identified as follows from the sh diag:
WIC Slot 2:
        FT1 BT8360
        WIC module not supported/disabled in this slot
        Hardware revision 1.5           Board revision G0
        Serial number     29689272      Part number    800-03279-04
        FRU Part Number     WIC-1DSU-T1=
        Test history      0x0           RMA number     00-00-00
        Connector type    Wan Module
        EEPROM format version 2
        EEPROM contents (hex):
          0x20: 02 11 01 05 01 C5 05 B8 50 0C CF 04 00 00 00 00
          0x30: 80 00 00 00 03 01 11 01 FF FF FF FF FF FF FF FF
What this says to me is that it's recognized, but the port needs to be enabled. I've searched high and low and have been unsuccessful at finding how to do this.
Chris
Kenneth Sharp
Christopher,
    I'm sorry to tell you, but the older WIC-1DSU-T1 card is not supported in the 2811.  You'll need to get the WIC-1DSU-T1-V2 card.
A full list of WICs and modules for the 2800 series routers is available at:
http://www.cisco.com/en/US/products/ps5854/products_relevant_interfaces_and_modules.html#multiflex
Also, about halfway down the following page, you can see a list of unsupported WICs in the 2800 series.  (search on page for 'Unsupported')
http://www.cisco.com/en/US/prod/collateral/routers/ps5854/prod_qas0900aecd80169bd6.html
I hope this helps clear the confusion.
   - Ken
Hmm...coulda swore I saw it on the approved list...oh well. Thanks for the info, Kenneth!
