iPerf % packet loss question
jdlucado1
I'm a noob when it comes to iPerf, I only know what i've read online over the past couple of days and have never used the application myself. My question is this, when someone runs an iPerf test on a link and the % packet loss comes back let's say at 10%, does that mean that 100 out of every 1000 UDP packets was dropped OR does it mean that the throughput on the link was 90% and that's the amount of bandwidth available to the host.
Does that make sense?
So if I have a 50 Mbps WAN link and I run iPerf over it, and I get a 20% packet loss, that means that I pushed my content through at 40Mbps, not that one out of every five packets that runs over that circuit is dropped. Is that right?
Maybe, maybe not.
The 20% lost would represent 20% of your volume of traffic, or the missing 10 Mbps.  Whether that's 1 in 5 packets would depend on whether all your packets were the same size.  Also, even if all the packets were the same size, and you did lose 1 in 5, it doesn't follow you lose every 5th packet, just that you lost 20% of your packets across the measurement period.  (Again, percentage of loss is volume, so actual packet loss percentage might be higher or lower than your volume loss.)
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Your 10% is the lost against your total volume you try to transfer.
For example, if you have a gig link that hands off to a FE link, and the gig link sends it 110 Mbps, your FE link should transmit 100 Mbps, but drop 10 Mbps, which would be 10/110 = 9.09 % loss.
Okay, so it's not necessarily an indication that there is 9.09%packet loss on your network, meaning that your connection is so unreliable it's going to drop 9.09% of the time.
So if I have a 50 Mbps WAN link and I run iPerf over it, and I get a 20% packet loss, that means that I pushed my content through at 40Mbps, not that one out of every five packets that runs over that circuit is dropped. Is that right? Sorry if I come off as dense, it's just that the term "packet loss" in this case comes off as a bit ambiguous (at least to me).
Appreciate the quick response!
Maybe, maybe not.
Joseph,
Ok, got it now! Thank you for the through explanation.
