IPS & SW Problem
tareqrebhi
Dear
I need to run my IPS through network i configured my sitch 3560 but when i entered this command :
monitor session 1 destination interface Fa0/24
i lost the connection with IPS.i put the monitoring IPS port at SW port/24 ....
what is the problem?
anandramapathy
Level 3
Level 3
you should enable incoming & outgoing traffic on this interface which is in the monitor command. Else it will only capture packets from the switch
