IPSEC Crypto Key not encrypted in running-config
CiscoBrownBelt
Level 6
Level 6
I use the 6 parameter in the following however key still shows in running-config on a ISR800 router. How do I make it appear encrypted format in running-config:
crypto isakmp key 6 TESTJ=KEY address 1234
2 Accepted Solutions
Define the pre-shared key in cleartext without the "6" e.g. "crypto isakmp key TESTJ=KEY address 1234" once the following commands have been configured:-
key config-key password-encrypt testkey123
password encryption aes
...the pre-shared key will then appear as encrypted in the running configuration.
Reference here.
No, it should not cause any impact if a tunnel is already established.
6 Replies 6
Reference here.
Awesome thanks again!
Entering this command for a tunnel that is currently up should not break it correct as it only applies to how the password is shown in the run or start config correct?
Thanks!
Looks like I had to make sure the "6" was still not displayed in running config for this to work.
