IPSEC ikev2
mark-halls
Hi, I have a question regarding IPSEC VPN using IKEv2 and certificates.
i have a standalone RootCA and subordinateCA that I have setup for my ASA 5500-x and I am trying to achieve setting up a VPN community using asdm 7.1. I have setup the VPN between two asa's with no problems, however, when I change the phases from ikev1 to ikev2 only and using my device certificate, my VPN drops.
I have added two trust points for my root and sub, followed by a device certificate. When I run crypto ca trust points it shows me the installed Certs for the root and sub but the device one shows as not authenticated and I am also getting authentication messages from the debug.
now, I know that phase1 will create the authentication  bn between the two peers, however, am I able to remove ikev1 option or will I always need this. Only, I need to use certificates for the ikev2 and thought I should remove ike1 as a business requirement.
can anyone help?
thanks
mark
0 Replies 0
