IPSec Main mode versus Aggressive mode
GW M
I have two Cisco 2911 routers communicating over the Internet using an IPSec site-to-site tunnel with pre-shared keys and isakmp aggressive mode. Can I reconfigure the routers to use isakmp main mode versus aggressive mode while still using pre-shared keys? Also, the main router where the site-to-site tunnels are being establish also supports IPSec client connections. If I change the router to main mode "crypto isakmp aggressive-mode disable"my IPSec clients no longer connect. Is there a way allow the clients to use isakmp main mode too or can they only use isakmp aggressive mode?
GW
If you have a "real" S2S connection (that is, on both routers you reference the other sides IP), then this should work also in main-mode with PSK. That would be the "normal" way to configure it. If it doesn't work in your scenario, then something else is going wrong there.
Below is the remote site config
crypto keyring site2site
pre-shared-key address x.x.x.50 key 6 xxxxxxxx
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp keepalive 10 periodic
crypto isakmp client configuration group remote-clients
key 6 xxxxxxxx
pool VPN-clients
acl 104
max-logins 1
crypto isakmp profile site-to-site
description Site to site VPN Tunnel profile connection
keyring site2site
match identity address x.x.x.50 255.255.255.255
keepalive 30 retry 3
crypto isakmp profile vpnclients
description VPN Clients profile connection
match identity group remote-clients
client authentication list vpnclientauth
isakmp authorization list vpngroupauth
client configuration address respond
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec fragmentation after-encryption
crypto ipsec df-bit clear
crypto dynamic-map SDM_DYNMAP_1 2
set transform-set ESP-3DES-SHA
set isakmp-profile vpnclients
reverse-route
crypto map SDM_CMAP_1 1 ipsec-isakmp
set peer x.x.x.50
set security-association idle-time 86400
set isakmp-profile site-to-site
match address 100
crypto map SDM_CMAP_1 65535 ipsec-isakmp dynamic SDM_DYNMAP_1
interface GigabitEthernet0/0
ip address dhcp client-id GigabitEthernet0/0
I just see that I didn't read your message right. Not the S2S-tunel stops working but the client-VPN. That is normal. For EzVPN with PSKs, aggressive mode is used. Only if you migrate to certificate-based authentication, main mode is used.
Are you sure that your S2S-VPN is also using aggressive mode? Does "show crypto isakmp sa detail" show that?
The site to site VPN is working and the VPN client is working but I want the site to site VPN to use main mode versus aggressive mode.
GW
