IPsec passthough
1_1
                   Ok first I'll go over my setup and then the problem I have.
Comcast SMCD3 cable gateway (required for statics with bisiness class service.
Cisco 3745 w/ NM-1GE (link to the SMC) and 2x NME-16ES-1G-P
the NM-1GE is GI 2/0
the links to the etherswitches are Gi 1/0 and GI 3/0
Then I have OSPF routing between all three, and the etherswitches are handleing the intervlan routing (the DHCP server is handing out 2 default routers to the DHCP clients which then for the ones that support it load balance between the two.
the inside IP layout is
3745
gi 1/0 10.254.254.1 /30
gi 3/0 10.254.254.5 /30
Etherswitch one
Vlan 200 10.254.254.2 /30
with vlan interface IP's ending in 1
Etherswitch two
Vlan 201 10.254.254.6 /30
with vlan interface IP's ending in 253
Vlan 2 10.0.2.0 /24
Vlan 3 10.0.3.0 /24
Vlan 4 10.0.4.0 /24
Now on to the problem
from a computer on vlan 2 (or any of the vlans) I can't open a microsoft ipsec tunnel to a ISA server out on the internet
if I plug directly into the SMC with the computer and make use of my spare public IP then I can
It used to work at some point in the past it worked, though I haven't tested vpn after every network change (as I don't vpn that offten)
ok and heres the nat config
interface GigabitEthernet1/0
description Link to NME-16ES-1G-p
ip address 10.254.254.1 255.255.255.252
ip nat enable
ip virtual-reassembly
ip ospf 1 area 0
ipv6 address --------:200::1/64
ipv6 ospf 1 area 0
interface GigabitEthernet3/0
description Link to NME-16ES-1G-p (number 2)
ip address 10.254.254.5 255.255.255.252
ip nat enable
ip ospf 1 area 0
ipv6 address --------:201::1/64
ipv6 ospf 1 area 0
interface GigabitEthernet2/0
description Link to Comcast
bandwidth 76000
ip address 75.x.x.35 255.255.255.248 secondary
ip address 75.x.x.36 255.255.255.248 secondary
ip address 75.x.x.37 255.255.255.248 secondary
ip address 75.x.x.33 255.255.255.248
ip access-group 110 in
ip nat enable
ip ospf 1 area 0
negotiation auto
ip route 0.0.0.0 0.0.0.0 75.x.x.38
ip nat pool RLH1 75.x.x.35 75.x.x.35 netmask 255.255.255.248 add-route
ip nat pool RLH2 75.x.x.36 75.x.x.36 netmask 255.255.255.248 add-route
ip nat pool RLH3 75.x.x.37 75.x.x.37 netmask 255.255.255.248 add-route
ip nat source list 1 pool RLH1 overload
ip nat source list 2 pool RLH2 overload
ip nat source list 3 pool RLH3 overload
access-list 1 permit 10.0.2.0 0.0.0.255
access-list 1 deny any
access-list 2 permit 10.0.3.0 0.0.0.255
access-list 2 deny any
access-list 3 permit 10.0.4.0 0.0.0.255
access-list 3 deny any interface GigabitEthernet1/0
ip nat enable
ip ospf 1 area 0
ipv6 ospf 1 area 0
ip nat enable
ip ospf 1 area 0
ipv6 ospf 1 area 0
bandwidth 76000
ip nat enable
ip ospf 1 area 0
negotiation auto
5 Replies 5
1_1
Anyone have any suggestions?
Hi Ricky,
What kind of IPsec client are you using? Is it a Cisco VPN Client v5.x or some other client? I wonder if it supports NAT Traversal for IPsec by UDP-encapsulating it so that it can pass through a NAT/PAT box. You could perhaps do a Wireshark dump on the PC running the IPsec client to see what kind of packets are being sent - and perhaps if any packets get back in return.
In addition, your Gi2/0 interface is configured with ACL 110 in the inbound direction. What exactly does this ACL contain? Assuming your IPsec client indeed supports NAT-T then this ACL should allow UDP segments sourced from UDP ports 500, 4500 and 10000. Can you verify this?
Best regards,
Peter
THe client is the default MS client the vpn server is a MS ISA server
I know it worked in the past but as I didn't recularly test it I'm not really sure when it stopped working, though my microcell (ATT mini personal cell tower thing) which has to vpn to att stoped working only recently
Heres ACL 101 and 110
access-list 101 permit ip host 10.0.3.11 any
access-list 101 deny ip any any
access-list 110 deny tcp any 75.x.x.32 0.0.0.7 eq discard
access-list 110 deny tcp any 75.x.x.32 0.0.0.7 eq daytime
access-list 110 deny tcp any 75.x.x.32 0.0.0.7 eq chargen
access-list 110 deny tcp any 75.x.x.32 0.0.0.7 eq telnet
access-list 110 deny tcp any 75.x.x.32 0.0.0.7 eq finger
access-list 110 deny tcp any 75.x.x.32 0.0.0.7 eq 135
access-list 110 deny tcp any 75.x.x.32 0.0.0.7 eq 136
access-list 110 deny tcp any 75.x.x.32 0.0.0.7 eq 137
access-list 110 deny tcp any 75.x.x.32 0.0.0.7 eq 138
access-list 110 deny tcp any 75.x.x.32 0.0.0.7 eq 139
access-list 110 deny udp any 75.x.x.32 0.0.0.7 eq snmp
access-list 110 deny udp any 75.x.x.32 0.0.0.7 eq snmptrap
access-list 110 deny tcp any 75.x.x.32 0.0.0.7 eq 445
access-list 110 deny tcp any 75.x.x.32 0.0.0.7 eq 593
access-list 110 deny ip host 12.203.209.1 any
access-list 110 permit ip any any
Ricky,
Thank you. I do not see any problem in the ACL 110. Where is the ACL 101 used? Also, can you perform the test with Wireshark on the client? I am interested in knowing how are the IPsec packets being encapsulated.
Best regards,
Peter
I'll do some wireshark capturing a bit later
heres where 101 is used
class-map match-all game
match access-group 101
class-map match-any Xbox360
match ip dscp ef
policy-map game
class game
set ip dscp ef
policy-map Xbox360
class Xbox360
bandwidth 1024
