IPSEC Tunnel between cisco-RV340 Router and TP-Link ER605 Router
Renatus-Roelofs
I was able to successfully create a tunnel between a cisco-RV340 router and a TP-Link ER605 Router... Both device show the Tunnel is created and up and running....
A tunnel between two ER605 devices working flawlessly, as well as between RV340 Routers....
Never the less I can not communicate over the tunnel no ping in either of the directions... Anybody has any idea what to do about this problem.
@Renatus-Roelofs
  On the other router, are you using the same network/mask but local is 10.95.26.0/24 and remote 192.168.178.0/24 ?
Basically, if you have phase1 and 2 working, the next thing to look at is the traffic of interest.
