IPSec Tunnel up but cannot ping remote Tunnel IP
alfonso.cornejo
Level 3
Level 3
I have configured a gre IPSEC tunnel and everything was working fine but suddenly i can't ping the tunnel ip address anymore, the two tunnels are showed as UP/UP, here is the configuration:
***Branch***
crypto isakmp policy 10
encr 3des
authentication rsa-encr
group 2
crypto isakmp keepalive 3600
crypto ipsec transform-set xxx-trans-3des esp-3des esp-sha-hmac
crypto key pubkey-chain rsa
addressed-key 10.233.172.1 encryption
  address 10.233.172.1
  key-string
   **** key ****
  quit
crypto map mapa 502 ipsec-isakmp
set peer 10.233.172.1
set transform-set xxx-trans-3des
match address lista
qos pre-classify
interface Tunnel502
bandwidth 4000
ip address 10.233.217.182 255.255.255.252
ip mtu 1400
ip tcp adjust-mss 1200
qos pre-classify
keepalive 3 3
tunnel source FastEthernet0/0
tunnel destination 10.233.172.1
service-policy output ring-tunnels
interface FastEthernet0/0
ip address 10.233.172.3 255.255.255.192
duplex full
speed 100
negotiation auto
arp timeout 900
crypto map rsvtu62-baa01-7206
ip access-list extended lista
permit gre host 10.233.172.3 host 10.233.172.1
***Central Site***
encr 3des
group 2
addressed-key 10.233.172.3 encryption
  key-string
   **** key ****
  quit
set peer 10.233.172.3
match address lista
qos pre-classify
interface Tunnel 502
bandwidth 4000
ip address 10.233.217.181 255.255.255.252
ip mtu 1400
qos pre-classify
keepalive 3 3
tunnel source GigabitEthernet0/2
tunnel destination 10.233.172.3
permit gre host 10.233.172.1 host 10.233.172.3
If i remove the crypto map from the wan interface the tunnel goes down, if i put it again it goes up and the crypto session is stablished but i can't ping from the branch the ip address 10.233.217.182 of the central site.
Any ideas?
Thanks in advance!
16 Replies 16
I just finished checking the configuration and the procedure and everything looks normal, i have some others tunnels configured in the same way and they are woking fine, if there was a problem with the rsa key, ipsec policy, isakmp, etc that should be logged on the router or showed in a debug command but there is nothing that shows at least a little clearly what is going on...
Any other ideas?
Thanks in advance!
It is extreme hard to troubleshoot when it is working. Is it possible that you turn on debug crypto isa sa and log that to a syslog server until it is not working? I know this might not be possible for a production environment, but right now, I am kind of run out of clue why this is not working.
jerry
