IPsec tunnel with VTI
Mmiselo
Good day,
Below are the configurations I have on a Cisco 2900 series router, the tunnel connects to the Microsoft Azure VM. The type of config we have are also generated from the VM to match what they have on the tunnel.
The issue we are having is that the vti tunnel interface keeps flapping. Is this an issue or a reason why it's flapping? When we telnet through the tunnel all seems to be fine.Not sure if the flapping is an issue as the client has been getting some errors.
Is there a way we can configure a tunnel without the vti tunnel interface and still use ikev2? To have the tunnel with the same settings we have on the config below.
crypto ikev2 proposal azure-proposal1
encryption 3des
integrity sha1
group 2
crypto ikev2 policy azure-policy1
crypto ikev2 keyring azure-keyring1
peer CLIENT
  address 13.74.191.239
  pre-shared-key ****************
crypto ikev2 profile azure-profile1
match address local interface GigabitEthernet0/0
match identity remote address 13.74.191.239 255.255.255.255
authentication local pre-share
authentication remote pre-share
 cypto ipsec transform-set CLIENT1 esp-aes 256 esp-sha-hmac
crypto ipsec profile vti
set transform-set CLIENT1
set ikev2-profile azure-profile1
interface Tunnel120
ip address 169.254.0.1 255.255.255.0
ip tcp adjust-mss 1350
tunnel source GigabitEthernet0/0
tunnel mode ipsec ipv4
tunnel destination 15.75.192230
tunnel protection ipsec profile vti
ip route 10.145.0.0 255.255.0.0 Tunnel120 name CLIENT-LAN-Range
Nelson
Richard Burts
Nelson
If you want to change it and not use VTI you could probably rewrite it to use GRE with IPsec and use IKEv2. But I am not sure why you would do that. VTI is the newer approach to tunneling with IPsec and simplifies some of the things that you would need to do with GRE (such as configuring crypto maps).
We do not have enough information to know what is causing the flapping. But I very much doubt that changing from VTI to GRE would solve that problem.
Rick
Rick
Hi Rick,
Thanks for the response!
I agree that the vti route makes everything easier and I would prefer to stick to the current setup. The only worry is the flapping of the VTI and almost I thought it's a normal behavior.
I just want to make sure it's not the flapping that is affecting traffic.
Nelson
Nelson
We do not have enough information to identify the cause of the flapping. It might be a crypto issue that causes the flapping. I have had experience where something was going on with ISAKMP and would cause the tunnel to flap. Or it might be something else. Perhaps a debug of ISAKMP might be a place to start your troubleshooting?
Rick
Rick
