IPsec VPN issue...
ajf303
I am establishing IPsec VPN b/w to asa in gns...
VPN tunnel is not estblished. here i have enclosed asa conf...
can any one tell me am i configured in right way and is any ather conf needed...
guibarati
Level 4
Level 4
They are missing the route :-)
The ASA will only check the crypto map on the interface, your case (outside), when the packet is routed out of it.
Your ASAs are missing route, so they don't know where to send the packet and the crypto map is never checked/applyed.
You need to create a route to the remote network.
In your case you need to point
ASA2
route outside 192.168.2.1.0 255.255.255 10.10.10.2
ASA1
route outside 192.168.2.2.0 255.255.255 10.10.10.1
Rate helpful posts.
added following these routes as well as both ASA,
In ASA2, route outside 192.168.1.0 255.255.255.0 10.10.10.2
In ASA1,  route outside 192.168.2.0 255.255.255.0 10.10.10.1
But,
Outpt also the same, i am unable to reach the ASA GW.
