IPSec VPN RV325
Hello all.
i have recently had to change my network so now my RV325 is sat behind a Mitel Boarder Gateway in network edge mode. The wan address is now on the MBG with the MBG LAN side 192.168.200.254 hitting the WAN port on the RV325 - 192.168.200.1
The LAN side is working fine for both Voice and data.
The issue now is the VPN RV325 to RV320. I have tried to use WAN2 with a separate WAN IP address but just can’t seem to get to connect at all. Can you use WAN1 and WAN2 for separate purposes? Should WAN1 for my local voice and data with WAN2 for my VPN work?
If not that will port forwarding via the MBG be an option? If this is the case, do you guys know what ports I need to open?
I have seen UDP 500 and UDP 4500. Anymore I need to know about?
0 Replies 0
