IPSec VPN Tunnel Breaks When OSPF is Applied
Wizard4777
I am trying to configure OSPF for my remote sites to connect back to HQ. IPSec VPN tunnels are up and everything works fine until i apply OSPF at the HQ and the remote branches.
The branches seem to come on for 2 minutes and off for 3 minutes and so forth.
When I do a
show ip ospf neighb
command, it shows my remote branches with state as FULL/-. I don't know what that means and how to fix that too.
Wizard4777
removed ospf and used rip and it all works fine
Thank you for your responses
9 Replies 9
Georg Pauwen
post the running configs of the HQ and one of the branch routers...
Everything works fine without OSPF, just on static routes. I just wanna know why when I put OSPF into the interfaces, the links go on and off.
do you have the configs ? Make sure you use VTIs and not crypto maps...
pman
Do you have a Point-to-Point GRE over IPsec configuration?
If so maybe because of recursive routing error message.
If not, suggest that you follow @Georg Pauwen instructions and post running-config
it is a point to point gre tunnel with ipsec
with VTIs, the configs should look something like this:
interface GigabitEthernet0/1
description LAN
interface Tunnel1
description IPSec Tunnel to Site X
ip address 172.16.1.1 255.255.255.0
ip ospf network broadcast
ip ospf mtu-ignore
tunnel source GigabitEthernet0
tunnel mode ipsec ipv4
tunnel destination 100.100.100.2
tunnel protection ipsec profile IPSEC_PROFILE
router ospf 1
router-id 1.1.1.1
network 172.16.1.0 0.0.0.255 area 0
network 192.168.1.0 0.0.0.255 area 0
1. check if the following log exist:
 % TUN-5-RECURDOWN
2. maybe a misconfiguration that causes the router to try to route to the tunnel destination address using the tunnel interface itself (recursive routing)
3. A temporary instability caused by route flapping elsewhere in the network
in this case:
try to add this route:
ip route x.x.x.x 255.255.255.255
serial 0
- where x.x.x.x is the tunnel destination address (under interface tunnel configuration)
- and serial 0 is the interface that point to x.x.x.x address
references in case of recursive routing error:
https://www.cisco.com/c/en/us/support/docs/ip/enhanced-interior-gateway-routing-protocol-eigrp/22327-gre-flap.html
in case of GRE Tunnel over IPsec with OSPF i attached this link which explains how to properly design the solution:
https://www.cisco.com/c/en/us/support/docs/security-vpn/ipsec-negotiation-ike-protocols/14381-gre-ipsec-ospf.html#t3
Hello
Possible recursive routing, make sure the tunnel SIP/DIPs (source/destination ips) are not being advertised through the tunnels themselves, Also checked the ospf network types, on tunnel interfaces they should be point-to-point (p2p) however if hub/spoke design preferable set to possible  broadcast/non broadcast types.
Kind Regards
Paul
Wizard4777
