IPSEC VPN
CSCO10320953
Hi All,
Please confirm whether 1841(C1841-ADVSECURITYK9-M), Version 12.4(3i)) support VPN connectivity without VPN module?
guruprasadr
Level 7
Level 7
HI,
1841 will support only Software based VPN Services.
Use: c1841-advsecurityk9-mz.124-3h.bin if you are going to run IPSec Tunnels in an HUB & Spoke Connectivity.
Pls RATE if HELPS.
Best Regards,
Guru Prasad R
Guru prashad,
Can i do site to site vpn after this IO.
