ipv4 node unable to bing ipv6 node in my dualstack topology .... i wonder if i miss some thing
auoobe_april
i design a dual stack topolgy with three routers one in the middle is running ipv4 only and the others in the sides is running ipv6 made a tunnele so host in ipv6 only networks can ping but when i try to ping ipv6 host from ipv4 network i get a massege distenation unreachble ? can you help me to translate
ipv4 host cannot ping ipv6 host.
ishan2106
can you share the result ? also ur interface config ?
did you ping with 'ping6' command or simple 'ping' ?
Please elaborate so that we can try to get your ans.
tnx
