IPv6 advertisement with ISP
Deeprag77
We want to migrate our entire network from IPv4 to IPv6 and have recently bought IPv6 /48 pool with AS number from APNIC.
At the perimeter level, we have L2 device and there are 2 ISP's who have configured static routing using their own IPv4 pool and AS numbers.
Now we want to advertise our own IPv6 pool using our own AS number.
I have told them to configure it statically as we do not have L3 device at the perimeter and to use IPSLA for tracking in case of link  failure.
The ISP's are rejecting the solution saying that it can be achieved using eBGP only and not using static routing.
Need some urgent solution to achieve the requirements by using static routing only.
Harold Ritter
Why not use BGP if this is the ISP preferred approach? Configuring BGP would not be that difficult and would make your setup standard, as opposed to using a static route with some link detection mechanism.
