IPv6 DHCP pool configuration
Cisco Freak
Level 4
Level 4
Hello All,
I was trying to configure a IPv6 DHCP pool in a router in GNS3.
R1(config-dhcp)#ipv6 dhcp pool Test
R1(config-dhcp)#?
IPv6 DHCP configuration commands:
default Set a command to its defaults
dns-server DNS servers
domain-name Domain name to complete unqualified host names
exit Exit from DHCPv6 configuration mode
no Negate a command or set its defaults
prefix-delegation IPv6 prefix delegation
sip SIP Servers options
R1(config-dhcp)#address prefix 2001:1111:1111:1111::/64
% Invalid input detected at '^' marker.
It doesn't give an option to configure a address prefix inside the DHCP pool. Any thoughts on this?
CF
Peter Paluch
Hi CF,
Unfortunately, the IOS you are running does not yet support DHCPv6 for end clients (those that request IA_NA assignments). This DHCPv6 implementation only supports Prefix Delegation which is a different, unrelated functionality.
What IOS version are you running? The address prefix command has first been added in the 12.4(24)T release.
Best regards,
Peter
I am running c3640-a3js-mz.124-25d in GNS3. Let me try upgrading to newer code.
CF
