IPv6 NAT-PT Problem
kengyiam
Hi guys,
I have a setup with the intention of routing between IPv6 and IPv4. In this case I uses NAT-PT to translate these 2 different network protocols. Below is my v6 router's configuration:
r0uter: 3745 12.2(13)TR, Host_A_winxp(IPv6 addr=2006::208:2ff:fe67:d255/64), Host_B_winxp(IP addr=172.16.1.10/24):
ipv6 unicast-routing
interface FastEthernet0/0
ip address 172.16.1.1 255.255.255.0
duplex auto
speed auto
ipv6 nat
interface FastEthernet0/1
no ip address
duplex auto
speed auto
ipv6 address 2006::1/64
ipv6 nat
ipv6 nat v6v4 source 2006::208:2ff:fe66:d255 172.16.1.20
ipv6 nat prefix 2000::/96
! end
Everything seems ok but when I ping from Host A to Host B (ping 2000::<dest's ip in hexa>), it came out debug msg on the router stating "ipv6 nat: dropping v6tov4 packets". I had also tried v4v6 translation and ping from host b to host a and it works.
There isnt any useful info out in the net and therefore I hope there will be any IPv6 experts here who can advise me on the above problem? Please kindly elaborate as detail as possible.
Thanks in advance.
pkhatri
Level 11
Level 11
Could you try the following config instead:
duplex auto
speed auto
ipv6 nat
no ip address
duplex auto
speed auto
ipv6 nat
ipv6 nat v6v4 source 2006::208:2ff:fe67:d255 172.16.1.20
ipv6 nat v4v6 source 172.16.1.10 2006::2
ipv6 nat prefix 2006::/96
Then, ping the address 2006::2 from host A, which should be translated to host B's address of 172.16.1.10.
Let me know how you go....
Pls rate the post if you find it useful.
Paresh.
