IPV6 output interface
sanjay.ccie
I have two routers connected R1-> F0/0 -----F0/0-> R2.
I have enabled ipv6
I try to ping the following address :FE80::CE00:1FF:FEB8:0
and specify the output interface. and get the error given below.
What is supposed to be the output interface in this case ?
R1#ping FE80::CE00:1FF:FEB8:0
Output Interface: fastethernet 0/0
% Bad interface
thanks
Harold Ritter
Sanjay,
You have to remove the space between the interface type and the interface number.
Hope this helps,
