IPv6 over IPv4 IPSec issue
bvl
I'm trying to set up IPv6 over IPv4 IPSec on a C1101-4P with IOS-XE 16.12.04, but the IPv6 packet silently disappears.
Crypto works fine with only IPv4 (tunnel mode ipsec ipv4), traffic works both ways.
Switching to IPv6 over IPv4 (tunnel mode ipsec ipv4 v6-overlay), and packets are dropped silently.
Tunnel config:
interface Tunnel0
 no ip address
 ipv6 address 2001:DB80:123::1/128
 ipv6 enable
 ipv6 mtu 1400
 tunnel source GigabitEthernet0/0/0
 tunnel destination <dst IP>
 tunnel protection ipsec profile <profile>
IPSec SA and sessions is up and working as far as I can tell. Same as for working IPv4 only.
IPv6 routing is simple:
ipv6 route ::/0 tunnel 0
Debug log for IPv6 packets when pinging dst 2001:db88::1 from lo 0 with ipv6 add 2001:d900::1/128:
IPv6-Fwd: SAS on intf Loopback0 picked source 2001:D900::1 for 2001:DB88::1
*Apr 14 23:31:31.878: IPv6-Fwd: Destination lookup for 2001:DB88::1 : i/f=Tunnel0, nexthop=2001:DB88::1
*Apr 14 23:31:31.878: IPV6: source 2001:D900::1 (local)
*Apr 14 23:31:31.878:       dest 2001:DB88::1 (Tunnel0)
*Apr 14 23:31:31.878:       traffic class 0, flow 0x0, len 100+0, prot 58, hops 64, originating
*Apr 14 23:31:31.878: IPv6-Fwd: Created tmp mtu cache entry for 2001:D900::1 2001:DB88::1 00000000
*Apr 14 23:31:31.878: IPv6-Fwd: L3 injection feature enabled: skipping pak_encap
Debug platform packet-trace with same ping:
Packet: 0           CBUG ID: 111
Summary
  Input     : internal0/0/rp:0
  Output    : internal0/0/rp:0
  State     : DROP 33  (Ipv6NoRoute)
  Timestamp
    Start   : 192459559663440 ns (04/14/2022 23:35:27.121780 UTC)
    Stop    : 192459559686360 ns (04/14/2022 23:35:27.121803 UTC)
Path Trace
  Feature: IPV6(Input)
    Output      : <unknown>
    Source      : 2001:d900:0000:0000:0000:0000:0000:0001
    Destination : 2001:db88:0000:0000:0000:0000:0000:0001
    Protocol    : 58 (IPv6-ICMP)
Debug platform packet-trace (fia):
Packet: 0           CBUG ID: 116
Summary
  Timestamp
    Start   : 192578566639320 ns (04/14/2022 23:37:26.791553 UTC)
    Stop    : 192578566669040 ns (04/14/2022 23:37:26.791582 UTC)
Path Trace
    Output      : <unknown>
  Feature: DEBUG_COND_INPUT_PKT_EXT
    Entry       : Input - 0x10e897d8
    Output      : <unknown>
    Lapsed time : 53 ns
  Feature: DEBUG_COND_APPLICATION_IN_EXT
    Entry       : Input - 0x10e897cc
    Output      : <unknown>
    Lapsed time : 93 ns
  Feature: DEBUG_COND_APPLICATION_IN_CLR_TXT_EXT
    Entry       : Input - 0x10e897c8
    Output      : <unknown>
    Lapsed time : 0 ns
  Feature: IPV6_INPUT_DST_LOOKUP_CONT_EXT
    Entry       : Input - 0x10ea4768
    Output      : <unknown>
    Lapsed time : 186 ns
  Feature: IPV6_INPUT_DST_LOOKUP_CONSUME_EXT
    Entry       : Input - 0x10ea4528
    Output      : <unknown>
    Lapsed time : 306 ns
  Feature: IPV6_INTERNAL_INPUT_SRC_LOOKUP_ISSUE_EXT
    Entry       : Input - 0x10ea4788
    Output      : <unknown>
    Lapsed time : 173 ns
  Feature: IPV6_INTERNAL_INPUT_SRC_LOOKUP_CONT_EXT
    Entry       : Input - 0x10ea4784
    Output      : <unknown>
    Lapsed time : 200 ns
  Feature: IPV6_INTERNAL_INPUT_SRC_LOOKUP_CONSUME_EXT
    Entry       : Input - 0x10ea4780
    Output      : <unknown>
  Feature: LFTS_INJECT_PKT_EXT
    Entry       : Input - 0x10e8a5cc
    Output      : <unknown>
    Lapsed time : 53 ns
  Feature: IPV6_INTERNAL_FOR_US_EXT
    Entry       : Input - 0x10ea4540
    Output      : <unknown>
    Lapsed time : 280 ns
  Feature: IPV6_PREF_TX_IF_SELECT_EXT
    Entry       : Input - 0x10ea47a8
    Output      : <unknown>
    Lapsed time : 26 ns
  Feature: IPV6_INPUT_LOOKUP_PROCESS_EXT
    Entry       : Input - 0x10ea4538
    Output      : <unknown>
    Lapsed time : 4666 ns
Can anybody make sense of what's going wrong here?
bvl
Guys, thanks for helping out.
It suddenly started working. I have since repeated several different small changes. For instance with and without ip unnumbered. And they don't matter.
Seems the router was stuck in some state. After shutting down several interfaces and bringing them back up, it all started working.
Thanks again.
11 Replies 11
Did you looked into this:
Thanks for looking at this Flavio.
I have seen it, but can´t find any information on what this means, except the obvious it states.
But from the IPv6 packet trace it looks ip the destination address and find´s it should be sendt out tunnel 0.
I have tried setting a /64 on tunnel 0 and pinging an ipv6 address within the scope of that /64, but different from the interface it self, which shows up in the logg as sending on tunnel 0.
But no packet is ever sendt.
MTU world be my next idea.
Thanks for the follow up.
With v4 in v4 IPSec tunnel I can do a ping <address> size 1480.
And with v6 in v4, I don't even get size 48 to pass.
So I don't think MTU is an issue.
tunnel mode ipsec ipv4 v6-overlay <- the tunnel is IPv6 so this may be wrong
tunnel mode ipsec ipv6 v4-overlay <-replace it with this command
Can I see full config if failed.
Thanks for the tip MHM, but I think tunnel mode ipsec ipv4 v6-overlay is correct.
Going with pure IPv4 (tunnel mode ipsec ipv4) I can see a child-sa form with scope 0.0.0.0/0
Setting tunnel mode ipsec ipv4 v6-overlay deletes that child-sa and creates a new ::/0 child-sa.
Doing tunnel mode ipsec ipv6 v4-overlay results in no SA, actually no IP packets is exchanged between peers at all.
The config is pretty much like this:
ipv6 unicast-routing
interface Tunnel0
 ip unnumbered Vlan10
 ipv6 address 2001:DB80::1/64
 ipv6 enable
 tunnel destination <Strongswan GW>
 tunnel protection ipsec profile GCP_VTI_PRO
interface GigabitEthernet0/0/0
 ip address dhcp
 negotiation auto
interface GigabitEthernet0/1/0
 switchport access vlan 10
 switchport mode access
interface Vlan10
 ip address 172.16.2.1 255.255.255.0
 ip mtu 1370
 ip tcp adjust-mss 1300
ip route 0.0.0.0 0.0.0.0 Tunnel0
ip route <Strongswan GW> 255.255.255.255 GigabitEthernet0/0/0 dhcp
ipv6 route ::/0 Tunnel0
Removing vlan 10, removing ip unnumbered from tun 0, setting static ipv4 un tun 0, no ipv4 on tun 0 does not make any difference on the result.
Looking at show crypto sa and session show no counter changes when passing ipv6 packets.
Debug logg still ends with:
interface Tunnel0
 ip unnumbered Vlan10 <-Delete this
 ipv6 enable
 tunnel destination <Strongswan GW> <-if the Strongswan use IPv4
 tunnel protection ipsec profile GCP_VTI_PRO <- the pre shared key is 0.0.0.0 or ::/0 ? so to troubleshooting remove IPSec from tunnel to check the tunnel is UP/UP and then we will reconfig the IPSec profile.
ip route <Strongswan GW> 255.255.255.255 GigabitEthernet0/0/0 dhcp <- IP address must be IPv4
bvl
Thanks again.
can you share the final config ?
Of course, here it is:
crypto ikev2 proposal CRYPTO_PP
 encryption aes-gcm-256
 prf sha384
 group 21
no crypto ikev2 proposal default
crypto ikev2 policy CRYPTO_POL
 proposal CRYPTO_PP
no crypto ikev2 policy default
crypto ikev2 keyring CRYPTO_KR
 peer CRYPTO
  address <IPv4_PEER>
  pre-shared-key <KEY>
crypto ikev2 profile CRYPTO_PRO
 match identity remote fqdn vpngw.com
 identity local fqdn net2.com
 authentication remote pre-share
 authentication local pre-share
 keyring local CRYPTO_KR
crypto ipsec transform-set CRYPTO_TS esp-gcm 256
 mode tunnel
crypto ipsec profile CRYPTO_VTI_PRO
 set transform-set CRYPTO_TS
 set pfs group21
 set ikev2-profile CRYPTO_PRO
interface Tunnel0
 no ip address
 ipv6 unnumbered Vlan11
 ipv6 enable
 tunnel destination <IPv4_PEER>
 tunnel protection ipsec profile CRYPTO_VTI_PRO
 ip address dhcp
 negotiation auto
 switchport access vlan 11
interface Vlan11
 no ip address
 ipv6 mtu 1370
 ipv6 tcp adjust-mss 1300
end
thanks for sharing
