SAP PMK command not found on Cisco ISR 4451
Desmond Lee
Hi, I needed something like the below configuration on the router for TrustSEC router to router link.
interface GigabitEthernet1/0/10
description for TRUSTSEC TESTING
cts manual
no propagate sgt
sap pmk 00000001234ABCDEF mode-list gcm-encrypt
But on the ISR 4451 router, I am unable to find the "sap pmk" command. Is the issue with ios or license ?
License
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None Smart License None
uck9 None Smart License None
securityk9 securityk9 Smart License securityk9
ipbase ipbasek9 Smart License ipbasek9
License Usage
securityk9 (ISR_4400_Security):
Description: securityk9
Count: 1
Version: 1.0
Status: IN USE
Export status: NOT RESTRICTED
Feature Name: securityk9
Feature Description: securityk9
Enforcement type: NOT ENFORCED
License type: Perpetual
ISR_4400_Hsec (ISR_4400_Hsec):
Description: U.S. Export Restriction Compliance license for 4400 series
Count: 0
Status: NOT IN USE
Export status: RESTRICTED - ALLOWED
Enforcement type: EXPORT RESTRICTED
License type: Invalid
IOS Version
Cisco IOS XE Software, Version 17.04.01a
Cisco IOS Software [Bengaluru], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.4.1a, RELEASE SOFTWARE (fc4)
RTR(config-if)#cts manual
RTR(config-if-cts-manual)#?
CTS manual configuration commands:
default Set a command to its defaults
exit Exit from CTS manual sub mode
no Negate a command or set its defaults
policy CTS policy for manual mode
propagate CTS SGT Propagation configuration for manual mode
RTR(config-if-cts-manual)#default ?
RTR(config-if-cts-manual)#default policy ?
static Configure policy to be applied on the link
RTR(config-if-cts-manual)#default propagate ?
sgt CTS SGT Propagation configuration
R06_RTR(config-if-cts-manual)#policy ?
R06_RTR(config-if-cts-manual)#policy static ?
sgt Source Security Group Tag to apply to untagged or non-trusted incoming traffic
R06_RTR(config-if-cts-manual)#propagate ?
Desmond
hslai
I moved this post to the routing forum from the NAC community as the topic is not related to ISE.
