ipv6 rip
The_guroo_2
Level 2
Level 2
quick one do we have to enable ipv6 router rip 1 in global mode as well if we want to use rip in ipv6 as i have noticed even if i use them on interface only still it get routes???? its the same with ospf as well can someone please clearify.....thanks
Giuseppe Larosa
Hello Khan,
probably if you don't want to customize RIPng you just need to enable it on interfaces.
see
http://www.cisco.com/en/US/docs/ios/ipv6/configuration/guide/ip6-rip.html#wp1038851
in the list of tasks the only mandatory task is that of interface level configuration
May be the router will create the instance automatically:
you should find this in sh run
ipv6 router rip
RIPng accepts a name for each instance (it has a process tag like IS-IS not a process number like OSPFv2)
Hope to help
Giuseppe
