IPv6 route-leaking in IOS XE
IBMeR
I try to replicate IPv6 routes from global vrf to user vrf.
But ipv6 address family of vrf doesn't have "route-replicate" command.
I found "import/export [ipv4|ipv6] unicast map", but again for IPv6 exist only "export" command:
was-edge-1(config-vrf-af)#export ?
ipv6 Address family based VRF export
map Route-map based VRF export
was-edge-1(config-vrf-af)#impo
was-edge-1(config-vrf-af)#import ?
map Route-map based VRF import
Know anybody way to import routes from global vrf?
Harold Ritter
It is definitly supported to use the import feature for ipv6 AF in recent XE images. What version of XE are you using?
ASR1001-X with Cisco IOS XE Software, Version 16.03.06
