02-04-2009 01:38 AM - edited 03-04-2019 01:06 AM
I'm setting up this type of tunnels but I can't find any good source of information about how to do it. As far as I know we need a routing protocol that provides you with the next hop in order to reach the IPv6 netwotk, for example BGP, but in my topology it is going to be easier, just 3 routers connected to a switch.
I have an IPv6 loopback in each of them and ethernet connections using IPv4 addressing, here are the configs:
/////////R1/////////
interface Tunnel0
no ip address
no ip redirects
ipv6 ospf 1 area 0
tunnel source Ethernet0/0
tunnel mode ipv6ip auto-tunnel
interface Loopback50
no ip address
ipv6 address 2001:1:1:1::1/64
ipv6 ospf 1 area 0
interface Ethernet0/0
ip address 10.0.0.1 255.255.255.0
half-duplex
router ospf 100
log-adjacency-changes
network 10.0.0.1 0.0.0.0 area 0
/////////R2/////////
interface Tunnel0
no ip address
no ip redirects
ipv6 ospf 1 area 0
no ip address
ipv6 address 2001:2:2:2::2/64
ipv6 ospf 1 area 0
ip address 10.0.0.2 255.255.255.0
half-duplex
router ospf 100
network 10.0.0.2 0.0.0.0 area 0
/////////R3/////////
interface Tunnel0
no ip address
no ip redirects
ipv6 ospf 1 area 0
no ip address
ipv6 address 2001:3:3:3::3/64
ipv6 ospf 1 area 0
ip address 10.0.0.3 255.255.255.0
half-duplex
router ospf 100
network 10.0.0.3 0.0.0.0 area 0
I'm doing something wrong but don't know what...
any idea?
thanks!
02-04-2009 12:25 PM
Hello Enrique,
the tunnel needs to have an IPv4 destination for sure:
you want to tunnel ipv6 packets inside ipv4 packets.
specify as tunnel destination the ipv4 address of the remote end
then you should also provide an ipv6 address to the tunnel to make it a logical interface that can connect two IPv6 clouds
see
http://www.cisco.com/en/US/docs/ios/ipv6/configuration/guide/ip6-tunnel.html#wp1055738')">http://www.cisco.com/en/US/docs/ios/ipv6/configuration/guide/ip6-tunnel.html#wp1055738
to use the tunnel you can run a routing protocol for IPv6 or use static routes
Hope to help
Giuseppe
02-05-2009 12:22 AM
Hi Giuseppe,
Thanks for your response, but I think you are refering to manual tunnels (point to point). In this kind of tunnel (point to multipoint) the destination addresss of the tunnel is created automatically based on a next hop address converted from IPv4 to IPv6. All documentation I have found use MP-BGP because this protocol is able to pass the next hop address in this format ::1.2.3.4 making the address IPv4 compatible. Maybe it can't be done with OSPF...
thanks!
02-05-2009 06:31 AM
Hello Enrique,
just a few lines down in the same config guide shows that an ipv6 address is to be configured also for automatic tunnel 6to4
What is not needed is an ipv4 destination and you are right on this.
see
Hope to help
Giuseppe
02-05-2009 06:39 AM
OK
You are right, I misunderstood what you meant. So, according to this we need statics or MP-BGP, right?
thnaks!
